PCV no cruise or 6 speed light - Road Glide Forums
post #1 of 4 (permalink) Old 09-06-2011, 11:21 PM Thread Starter
I have 2010 Road Glide Custom Installed Exhaust from 2011 Ultra CVO. Removed cat also SE Air cleaner. Installed PCV Had local shop Dyno. Bike ran fine 1st day. Then cruise stoped working along with 6speed light. Any one had this problem?
Waynedj is offline
post #2 of 4 (permalink) Old 09-07-2011, 05:45 AM
flhr95's Avatar
Do a search for this on this forum, I had the same issue and it's a setting in the power commander you have to turn off. I did it this weekend and it does work.
https://www.roadglide.org/showthread.php?t=7287
https://www.roadglide.org/showthread.php?t=10322
2010 Fltrx 96", Ness Stage 1 air set-up, V&H Power Duals with Hi Output Slip ons, PCV, SE204 Cams.
flhr95 is offline
post #3 of 4 (permalink) Old 09-07-2011, 08:35 AM
Got mine form fule moto. I guess they had it all set up when I got it with the new map so no I did'nt have the problem. Interesting though. After changing the gearing on my 07 WG I had put a speedo type healer on my 07 WG and the 6 gear light quit working.
JTultra is offline
post #4 of 4 (permalink) Old 09-07-2011, 11:45 AM
Wayne, I thought that I remembered something about this issue. Looks like if you follow the below listed URLs, you'll be able to fix your problem yourself. - Mike
mikek53 is offline
Check Engine Light/No Cruise after Bar Installation macabra11 Controls & Handlebars 5 03-24-2018 08:05 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 02:14 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 05:02 PM
6 gear light-no cruise? scsharp2260 Troubleshooting for Road Glides 6 06-05-2011 08:33 AM
