Thundermax Install - Road Glide Forums
post #1 of 4 (permalink) Old 09-18-2011, 11:24 AM Thread Starter
Thundermax Install
Well I had 30 miles on the bike when I installed the Thundermax so I don't really have a before and after comparison to give. But the bike seems to run really well after the install. I haven't ran it hard yet due to still being in the break in stage. Install was easy and straight forward. Make sure you buy, or have on hand a 7/8" 6 point offset o2 sensor wrench. I used a 3/8" drive with a 10" extension and it worked fine. I tried the straight socket first but the cut out was not wide enough for the flex covering up by the o2 sensor nut. Also don't be alarmed if after the install the ABS light stays flashing it goes off after you reach 10 mph and this is normal. I just never had ABS before and never noticed it before the install.
Mike
2012 FLTRX
Jerkey is offline
post #2 of 4 (permalink) Old 10-01-2011, 11:44 PM
mitssac's Avatar
Thunder max
I decided to go with the TTS. I put some miles on the machine before I installed it. I also installed Fullsac headpipe, and Zipper a/c with V&H slipon. Really smooth sound, and it goes. The Thundermax was a bit pricey and I wanted to stay with the HD ECM. (warranty ya know)
Take care.
mitssac is offline
post #3 of 4 (permalink) Old 11-19-2011, 08:49 PM
exammo's Avatar
As far as warranty is concerned, just remove the tmax and put the harley ECM back in before taking it to the dealer. No trace.
Jeremy
I own a Road Glide!!!!!!!!!!!!!!!
exammo is offline
post #4 of 4 (permalink) Old 11-25-2011, 11:36 PM
roadgliderick's Avatar
Send a message via Yahoo to roadgliderick
thats normal for the ABS to flash your install had nothing to do with the ABS light flashing.
2011 roadglide firemist orange carlini 17 inch eval bars, C&C solo seat, paugho true duals with thunder header slip ons , oil bud oil cooler, cool sac grips, alpine cda 105 head unit, alpine type r speakers with alpine 2150 digital amp,stratum timer cover derby cover and a/c cover sinister wheels 21 up front 18 rear woods 555 cams with adjustable push rods and tmax tuner. bad dad front wrap and bad dad rear summit fender with hide-a-plate and flush mount rear LEDs arlen ness big bags.
roadgliderick is offline
Thundermax Install dinggus ECM/Fuel Management systems 7 04-30-2016 01:05 PM
Thundermax on a stock 2010 RGC pab ECM/Fuel Management systems 18 12-22-2010 04:25 AM
Thundermax impression Rowdy ECM/Fuel Management systems 9 11-23-2010 09:27 PM
thundermax TBW roadgliderick ECM/Fuel Management systems 0 11-23-2010 12:36 AM
Zipper Thundermax Ranger58 ECM/Fuel Management systems 12 11-19-2010 10:26 AM
