Map for PC III USB for 06 RG - Road Glide Forums
post #1 of 3 (permalink) Old 05-24-2010, 07:28 PM
kimmer127
Guest
Posts: n/a
I have a 2006 Road Glide with Dual Rineharts (Not slip-ons), big sucker stage 2 and the 95 performance set up with cams. I have not seen a map for this specific set up. I can send my current ma by PM. I want to do some tweaks to improve my gas mileage (other than turning down the wick)
post #2 of 3 (permalink) Old 10-15-2010, 01:02 PM
Lucero62's Avatar
If you live near Dallas I recomend Sabin performance. They are certified tuning center for Power comanders and will do a custom map for 250... American!
I have an 05 88" w/ PC3 , Big air kit Rhinehart true duels. I had the canned map for my setup and after Sabin was done I went from 67 Hp 75 Ftlb Tq to 75HP and 84 ftlbtq...
I'm happy as she pulls much better from the stops... I'm rather heavy and do not feel as though the bike is working it's but off now!
Doni Lucero
2005 FLTRI
2002 FLTC
Lucero62 is offline
post #3 of 3 (permalink) Old 10-15-2010, 03:18 PM
kimmer127
Guest
Posts: n/a
Thanks very much Doni. I am in Canada and will find a dyno tester here.
02 RG- Thunderheaders 2:1, SE253 cams, SE 95ci w/ 10.25:1, SE A/C, PC-III, Blueprinte adrenilinecrash Dyno Results 5 04-14-2013 06:21 AM
PC III USB issue on install Mvfdfire Tech Area 3 12-02-2012 12:00 PM
PC III USB issue on install Mvfdfire ECM/Fuel Management systems 3 12-01-2012 02:30 PM
pc iii map needed 07 deluxe with 48cam bigpete1 Map Section 1 06-25-2012 07:53 AM
Power Commander III USB 99-01 Harley328 Classifieds Archive (3 months old+) 0 07-03-2011 09:51 PM
