PV tweaks "specs" needed - Road Glide Forums
post #1 of 3 (permalink) Old 01-25-2014, 10:46 PM Thread Starter
Boatnut's Avatar
Hi, anybody happen to know what the tps/map/rpm range is adjusted under the "tweaks" when you select Low or mid or high? Even knowing what input it references would help?
Looking to lean out the cruise range a touch ( 50-60MAP, 2,900-3,000rpm ) when on long slab ride and temps on the cool side to boost fuel economy. Do not want to adjust tune permanently.
If anybody knows of a better/easier way please let me know.
As an aside, can not get it to display VE or afr within the gauge options. I can select it, just get's no signal?
IBA #57135
2013 RGU
Boatnut is offline
post #2 of 3 (permalink) Old 01-26-2014, 12:11 PM
rageglide's Avatar
Look in the User Guide for WinPV, it has a graphic that shows which cells are affected by the different tweaks available in QuickTune.
Here's a PDF with same info, just found it. Go to the last page.
http://www.powercommander.com/downlo...icktune.01.pdf
2012 fltrx
rageglide is offline
post #3 of 3 (permalink) Old 01-26-2014, 09:58 PM Thread Starter
Boatnut's Avatar
Info
Thanks, really helpful....
IBA #57135
2013 RGU
Boatnut is offline
MicroTuner vs PC5 vs PV? Help needed from you FM gurus. beatlesfab4fan ECM/Fuel Management systems 3 08-22-2017 05:41 AM
2013 RG PV Map needed for 57H Cams Deadstroke Map Section 18 05-23-2016 08:57 PM
Canadian specs. JT10RG *General Road Glide Discussions/Pictures 11 05-28-2014 06:23 PM
2006 PV 1 map needed. satwatchers Map Section 3 03-16-2013 03:00 PM
