Re tune necessary? - Road Glide Forums
post #1 of 4 (permalink) Old 01-27-2014, 09:30 AM Thread Starter
jchar27's Avatar
Re tune necessary?
Changing the exhaust on my Dyna, happy with setup on my Road Glide, and was wondering. Currently it has a SE heavy breather, dealer download and v&h slip ons with stock headers.
I am ditching the headers and slip ons and going with a the Rinehart chrome crossovers. Do you guys think it will be necessary to re tune?
Thanks for the input
2018 CVO Road Glide, Black Earth/Vivid Black
Fuel Moto Road & Track 2 into 1, Fuel Moto custom K & N Air Cleaner, Redshift 468 cam, Power Vision.
2003 Super Glide 100th Anniversary Edition
jchar27 is online now
post #2 of 4 (permalink) Old 01-27-2014, 10:53 AM
4getNo1's Avatar
Yes, for sure.
You don't mention what year Dyna you have but, if she's a relatively recent year model that has an ECM, then you'll need to get some type of an after-market A/F ratio modification set-up at a minimum too. The stock ECM simply won't be able to cope by itself and she'll run so lean that it could result in engine damage.
Minimum choices include the ultra cheap resistive A/F ratio fudge type but personally, I would get at least a damn decent little piggy-back programmable type tuner like Fuel Moto sells. He includes a tailored program suited to your scoot and full support too.
In addition, if you're ever going to change cams just save spending $ twice. Go ahead and get a really good programmable tuner that can also adjust ignition settings too.
2013 FLTRX, Candy Orange
4getNo1 is offline
post #3 of 4 (permalink) Old 01-27-2014, 11:51 AM Thread Starter
jchar27's Avatar
That's what I figured.
The Wide Glide is a 2010. I have the FM Micro tuner on my RG, and it runs great, I have no plans for major engine mod's on that one, but this one is the toy so maybe I should go that route. Any recommendations? And where to purchase?
post #4 of 4 (permalink) Old 01-27-2014, 01:38 PM
4getNo1's Avatar
Yep. Use the same approach you did with your RG unless you do decide to go with cams too. Go to Jamie's Fuel Moto area here on RGF or click on his ad banner over on the left side of the screen. I bet he'll give you a forum discount too if you let him know you're a member and you can see what he thinks WRT cams at the same time.
BTW - I don't work for Jamie but he's so well respected, it's impossible to not recommend him (or the other sponsors too... it's just that Jamie has that modest tuner in-hand at his shop so it might be a good 1st stop anyway).
4getNo1 is offline
Both sides necessary? Headrope Aftermarket Accessories 10 05-13-2018 10:22 PM
Is gas tank removal necessary for EFI kit dsmith76 ECM/Fuel Management systems 7 12-25-2016 10:38 AM
speaker pads necessary? THEMASTERDESTROYER Audio 1 09-22-2015 01:58 PM
Is replacing cam bearings necessary? BigNorm Engine Related 20 07-02-2015 07:40 AM
Dyno Necessary or not? DaytonHD Intake and Exhaust 4 07-10-2012 10:08 PM
