Setup (((((help))))) - Road Glide Forums
post #1 of 5 (permalink) Old 10-03-2011, 08:54 AM Thread Starter
Hi Guys: I need some input here. I own 2011 RGC, I modified it by removing the CAT and adding Wild Pig slip on mufflers.
First Fact gas millage dropped. Second fact people following says that its running extremely rich (I guess they are drinking my gas ) hahah. I just purchased a Stage 1 air filter kit from HD and Iím asking. If I install this kit would I need the download or would I need a race tuner. Is it abnormal to run rich after you reduced back pressure by removing the CAT ? Would adding the air filter add air and reduce the richness of it ?
Kerryebro is offline
post #2 of 5 (permalink) Old 10-03-2011, 09:06 AM
you should use a tuner regardless if you are rich or lean as both are not good. Are you sure you did not get your O2 sensors switched around? Black connector goes to the rear header grey to front. less back pressure should not make you go rich unless your sensors are really confused.
jeff is offline
post #3 of 5 (permalink) Old 10-03-2011, 10:03 AM Thread Starter
I will check again but im pretty sure I put them back the way that they came out. Does a reduction in gas milage and the complaints of raw gas from following riders mean that its running rich ?
post #4 of 5 (permalink) Old 10-03-2011, 10:25 AM
maybe but with an afr test just a guess. General consensus is that most mods to free up breathing cause lean issues not rich but your ecm will try and keep your afr at 14.6 or close to it so if you are indeed rich it is because something is fooling your ecm and your O2 sensors are not giving correct feed back to the ecm. pull your trouble codes and see if you are throwing any.
jeff is offline
post #5 of 5 (permalink) Old 10-03-2011, 11:03 AM Thread Starter
If there is no CEL would it still show codes ? No running issue at all except the richness..
Help me complete my setup, please! MacSmacky Audio 5 05-25-2017 07:31 AM
HELP -- Why does my audio setup suck? Rycap Audio 15 05-13-2015 08:49 PM
Tire miles of 21 and 18 setup. Help. ERod62 Wheels and Tires 11 09-23-2013 09:51 PM
I need help with my audio setup jeffreyjjc Audio 2 04-28-2013 10:57 PM
Anyone have this setup? I need some help!! J.I.M.S. Windshields 4 10-30-2011 11:10 AM
