Went with the stage 1 download - Road Glide Forums
post #1 of 6 (permalink) Old 10-07-2011, 05:51 AM Thread Starter
RTWRK's Avatar
I have been struggling about getting the RGU set up with a tuner, my past experiences have been with a PC 3 and a SERT on my other scoots, I had more than my share of probelms with the PC 3, and now I'm running a SERT on my RK which has a bit of motor work, not bad, but if you dont get the right guy tuning it, it will be back to the dealer until you do.
I have been reading through all the suggestions and experiences here and decided to just do the stage one download from the dealer on the RGU, I am running Vance and Hines dresser duals with hi output mufflers and stage one air, no plans to do any further performance work so I gave it a shot for $175.
Yesterday was the test as we did a 200 mile mountain run through all conditions, it performed perfect (for me) gave the bike the right amount of snap on the throttle, and cooled it down nicely, fuel mileage seems to have improved only slightly ( I was testing the performance a lot ) but in general the bike runs a lot better, quicker, cooler, and has more throttle snap, basically all I was hoping for.
In my opinion, for what I was looking to get out of it, this worked perfectly!
RTWRK is offline
post #2 of 6 (permalink) Old 10-07-2011, 07:57 AM
4getNo1's Avatar
I went a similar way when I bought my 2010 FLTRX. Well... sort of similar anyway.
I had the chrome SE "Nightstick" (Supertrapp) and the SE AC added plus had the Stage 1 D/L done as part of the sale/delivery deal.
Then, when I got home, I added a Supertrapp "open" end cap and a few disks. That made performance noticeably better but she does run just a little lean (some pippity-pop on decel - very light, not severe). Been running great for about 18K miles that way though.
I still want a full custom pipe setup like you (ditch the CAT) and that's when I plan to add a tuner and maybe some mild cams... just not enough $ yet (retired).
2013 FLTRX, Candy Orange
4getNo1 is offline
post #3 of 6 (permalink) Old 10-07-2011, 09:18 AM
HarleyLance's Avatar
Glad the results are what you were looking for! When I had my StreetBob, I did pretty much the same as you - Harley SE slip ons, SE Heavy Breather and the Stage 1 download. The bike ran great. I bought an SE Supertuner as well, and had it installed at 1000 miles with a dyno. There was a small increase in HP and TQ, but not really much, so that showed me that the Stage 1 download on its own was just fine.
2010 Road Glide Custom FLTRX Scarlet Red - SE Stage 1 AC, Carriage Works Tornado Slip-on, SE SuperTuner, Jagg Fan Assisted Oil Cooler, 12" Windvest, HD Chrome Saddlebag Guards, Arc Audio MPAK 6
HarleyLance is offline
post #4 of 6 (permalink) Old 10-07-2011, 11:10 AM
Govdog76's Avatar
I am with you. I did not want to flagrantly void my warranty (only slight void it, like being a little pregnant) and I did not want to spend a ton of money on dyno work.
I did the SE air cleaner, street performance slip ons, and download. It is right for me (emphasis here). Not too loud, a bit more torquey, and the bike runs like a champ in all conditions.
Ian
Govdog76 is offline
post #5 of 6 (permalink) Old 10-12-2011, 07:56 PM
Yesca's Avatar
Ian, did you ditch the CAT also? If so, what type of head pipe are you using?
Darrell
2011 FLTRU - Black -
SE Ventilator A/C, SE Thunder Street Mufflers, V & H Power Duals, Power Vision
Yesca is offline
post #6 of 6 (permalink) Old 10-13-2011, 09:54 AM
007xd9's Avatar
Yesca, I went with the V&H Power Duals, the stage 1 download and Rush tips. I have gone ahead and put the Fuel Pak on too. It think it helps.
007xd9 is offline
Looking for 2017 M8 Stage 4 D&D w/ HD Heavy Breather PV download Easyryder01 Dyno Results 0 05-30-2018 08:20 PM
Boom Stage 2 download CVO RoadKing2013 Audio 0 08-22-2015 10:33 AM
Stage 1 download already? Gunny58 Fuel Moto 1 03-18-2011 08:02 PM
Download for PCV 107 build RoadGlide0611 Troubleshooting for Road Glides 0 02-13-2011 07:40 AM
Email Download Warning********** BillyBob Map Section 0 06-28-2010 12:52 PM
