Garage Door Opener/ECM Upload - Road Glide Forums
post #1 of 9 (permalink) Old 02-03-2014, 12:02 AM Thread Starter
Qwicker's Avatar
Question Garage Door Opener/ECM Upload
I lost my garage door opener after TTS tuning.
I uploaded the Fullsac map with TTS Mastertune after installing the Fullsac DX-pipe at my shop in town. Bike runs GREAT, but the garage door opener wouldn't work when I got home.
Is this the result of the ECM reprogramming, or unrelated? Anyone else seen this happen? It was working fine, but quit after the ECM upload. Would the reprogramming momentarily shut down the power to the garage door transmitter and cause it to drop the sync with the receiver? I have not yet tried to resync the transmitter/receiver, but I did have trouble getting it to sync when it was new, and had to take it to the dealer to get it working.
Qwicker is offline
post #2 of 9 (permalink) Old 02-03-2014, 03:26 AM
How is your garage door opener set up? Did you do the DIY garage door opener mod that is floating around?
post #3 of 9 (permalink) Old 02-03-2014, 12:38 PM Thread Starter
Qwicker's Avatar
No...although the converted push button opener installed with an intermittent switch is a great idea. Mine was factory installed on a CVO Road Glide Ultra. It was working fine until I did the ECM upload.
I actually have two garage door openers velcro'd to the inside of the flip down storage compartment doors...that works too, but the factory light switch actuator was nice.
Qwicker is offline
post #4 of 9 (permalink) Old 02-03-2014, 12:50 PM
RGKen's Avatar
Mine used to lose the code or something quite frequently and I would have to reset it it. Also I found that if I used the standard opener that came with the genie that the HD unit would interfere. They don't seem to work well together.
2018 FLTRXS
RGKen is offline
post #5 of 9 (permalink) Old 02-03-2014, 08:25 PM Thread Starter
Qwicker's Avatar
I have talked to both Fullsac and TTS, and neither of them have heard of a problem. I did have a problem with it when new, and the dealer somehow got it sync'd. I will try to sync the receiver/transmitter again and see if it works. If not, maybe I'll go back to the good ole' push button Genie opener remote.
It sounds as if they can be a bit temperamental at best.
Qwicker is offline
post #6 of 9 (permalink) Old 02-05-2014, 05:44 PM
RGKen's Avatar
I have heard many stories about the HD unit not working consistently if you still use your standard garage door opener. I no longer keep the car in the garage so I just quit using the standard one all together and went solely on the HD opener. Never had any issues that way. Don't know if that could be part of your issue but I seriously doubt the ECM is causing an issue with the opener.
2018 FLTRXS
RGKen is offline
post #7 of 9 (permalink) Old 02-05-2014, 08:06 PM Thread Starter
Qwicker's Avatar
OK....Total coincidence. The door closed in the morning when I left, and wouldn't open when I got home after the ECM reprogramming.
It turned out to be a toasted transistor/diode in the receiver in the garage. The LED on the receiver wasn't on, so I pulled it apart. Smelled like burnt electrical parts...and found the melted component on the board.
I guess it's off to HD to see if I can get the receiver without having to replace the transmitter under the front fairing.
Thanks for all the responses.
Qwicker is offline
post #8 of 9 (permalink) Old 02-05-2014, 08:11 PM
RGKen's Avatar
They do sell them separate. You shouldn't have an issue. Glad you found out what it was.
Sent from Motorcycle.com App
2018 FLTRXS
RGKen is offline
post #9 of 9 (permalink) Old 02-05-2014, 08:33 PM
Ohiobellboy's Avatar
Check ebay. Sometimes when a CVO owner upgrades, he forgets to add the receiver in with the sale/trade. I saw one for sale in an H-D board on FB a few weeks back. Might save you a few bucks.
A.K.A OBB
Ohiobellboy is offline
Tags
ecm upload , garage door opener , tts master tune
Garage Door Opener for $11.62 dklanecky Do-IT-Yourself 108 04-29-2015 03:55 PM
Very slick garage door opener, mo-door roadie13 Aftermarket Accessories 1 03-31-2015 07:50 PM
Wiring for your Electric garage door opener - DreamRider General Off-Topic Discussions 3 03-27-2011 05:53 PM
Moco garage door opener GATOR Classifieds Archive (3 months old+) 8 11-13-2010 06:24 AM
Garage Door Opener and More EZMotoTim Do-IT-Yourself 7 08-21-2010 07:31 PM
