Need a 110 starter tune powervision - Road Glide Forums
post #1 of 11 (permalink) Old 02-04-2014, 02:56 AM Thread Starter
Busted1's Avatar
Here's what I got.
SE 110
SE 110 heads with acr
Dave mackie tc598 cam
SE 10:5.1 forged dome pistons.
54mm TB
Stage 1 AC
True dual exhaust
I need a stater tune to get it running so I can break it in before the dyno. Thanks for any help and if you need any more info let me know.
2007
Busted1 is offline
post #2 of 11 (permalink) Old 02-04-2014, 09:12 AM
faststan's Avatar
Check with Fuel Moto. They are very helpful with Power Vision.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 11 (permalink) Old 02-04-2014, 12:05 PM Thread Starter
Busted1's Avatar
I did. They didn't have anything. I have a tune from dynajet but I don't know how close it is. It says it's for a 107 so I'm skeptical.
2007
Busted1 is offline
post #4 of 11 (permalink) Old 02-04-2014, 01:05 PM
faststan's Avatar
Check with the guys on the CVO board. You may be able to get some info there that is not referred to here.
http://www.cvoharley.com/smf/index.php?board=25.0
faststan is offline
post #5 of 11 (permalink) Old 02-04-2014, 02:15 PM
PGR
PGR's Avatar
Dynojet should be able to modify a 110 CVO file to work on your bike.
In theory the 107 file should be close enough to fire up the bike and do a bunch of autotune runs. Then you could download the file and send it to Dynojet for them to tweek to fit your build.
Ron..........................
PGR is offline
post #6 of 11 (permalink) Old 02-04-2014, 02:17 PM Thread Starter
Busted1's Avatar
Thanks. That probably never would have crossed my mind.
2007
Busted1 is offline
post #7 of 11 (permalink) Old 02-04-2014, 04:02 PM
Dynojet is very helpful if you call them. They helped me with my tune which was kinda out of the ordinary since I did it (the motor work) myself. After a few autotunes, I'm on the money and really strong!
2013 FLTRX Candy Orange 107 57H cams, Heads, V&H Monster Rounds, Jackpot header, Powervision, V&H VO2 intake, Daymaker LED headlights, 12" Buky Malo V1 bars, Self-painted inner fairing, Plasma Rods, Arlen Ness fire ring LED signals, Wind Splitter shield, J&M speakers, Rockford Fosgate amp, stock speakers installed inside fairing, DIY air ride suspension, Mono tube forks
mffi497 is offline
post #8 of 11 (permalink) Old 02-05-2014, 06:53 AM Thread Starter
Busted1's Avatar
I'm doing the work myself. Just got the bottom end back a few weeks ago. Slow go with limited time off right. Thanks guys.
2007
Busted1 is offline
post #9 of 11 (permalink) Old 03-01-2014, 06:48 PM
bigskyroadglide's Avatar
if you want a couple of PV tune for a 110, be happy to send you mine for my 12 CVO
48 states, 19K miles, 23 days
Hoka Hey Rider #622
2011
bigskyroadglide is offline
post #10 of 11 (permalink) Old 03-03-2014, 08:16 PM Thread Starter
Busted1's Avatar
Yeah big sky that would be good. Is it stock tune or has it been modified. I'll pm my email.
2007
Busted1 is offline
SE 110 & MVA Fuel Moto 110 Drop in & 107 piston/cylinder kits now available fuelmoto Fuel Moto 0 03-16-2017 04:22 PM
Powervision Auto tune Pro help Easyryder01 ECM/Fuel Management systems 22 02-09-2015 07:15 AM
SE 204 Cam Powervision tune kiohio Map Section 7 12-26-2014 07:11 AM
Powervision tune for dragos 565 cams? jj8823 Map Section 2 06-28-2014 04:12 PM
110" Stock High Torque Starter Thundercloud Classifieds Archive (3 months old+) 0 10-27-2011 09:24 PM
