SE Race Tuner - Road Glide Forums
post #1 of 26 (permalink) Old 02-06-2014, 10:06 AM Thread Starter
craigscooper's Avatar
SE Race Tuner
I am starting my winter project and was going with the SE Race Tuner, SE 211 cams and V&H power duals.
I was just curious as to why no one seems to be using the Race Tuner?
13 Ultra, -w- slip ons, otherwise stock.
craigscooper is offline
post #2 of 26 (permalink) Old 02-06-2014, 10:18 AM
fragmentum's Avatar
I am going to be using the SEPST when I get my bike back from HD for a warranty lower end rebuild. It will be interesting to learn this thing.
If your not living on the edge, you're taking up too much room...
fragmentum is offline
post #3 of 26 (permalink) Old 02-06-2014, 11:41 AM
Redbeard77's Avatar
I see a lot of folks on forums that use the SE tuner. Personally, from what I read the Power Vision seemed like it would be easier to work with so that's what I chose for my last two bikes. But the SE is very capable and I still may go with it when I get around to modding the RG.
Happiness is a warm motorcycle.
Redbeard77 is offline
post #4 of 26 (permalink) Old 02-06-2014, 12:05 PM
dirtyb's Avatar
I have a SERT and I'm happy with it. The biggest reason I went that route is the shop that dynoed my bike suggested it. He used them alot and I trusted his opinion.
2012 Road Glide CVO
2008 nightster (wifes ride)
2007 Street Glide Sold
2002 Heritage Sold
dirtyb is offline
post #5 of 26 (permalink) Old 02-06-2014, 12:42 PM
Craigmier's Avatar
I use this on my road glide custom and had one on my dyna fatbob. They are great. Never had an issue and have fantastic tunes on both bikes from the dyno. I never hear of people having problems with the screamin eagle tuner but I often see people having issues with every other tuner.
If you are going to be constantly tuning and retuning your bike on your own, without a dyno, then the other options make sense. I knew after I went stage 2 I was not going to do any more tuning as I would not need it until I do motor work. Which case I will do a re-tune with the SE tuner using a dyno.
'13 FLTRX - Big Blue Pearl - 16" Carlini Gangster Apes - V&H Power Dual Headers - CFR's - SE255 cams - SE Billet Cam Plate w/High Flow Oil Pump - SE Billet A/C - SERT - Dyno Tune - Daymakers - LRB Carbon Black Rotors - Progressive Suspension - H-D Vented Lowers - Bitchin Stitchin Custom Seat - Rockford Amp - Infinity 6.5's - GADS
Craigmier is offline
post #6 of 26 (permalink) Old 02-06-2014, 12:48 PM Thread Starter
That is just about exactly why I'm going with the SERT. "My" mechanic is a long time HD employee and he is probably comfortable with tuning the combo I'm going with. It makes sense to go with what you know so when it gets on the Dyno he will be able to wring out every ounce of power / torque out of my 103.
post #7 of 26 (permalink) Old 02-07-2014, 06:12 PM
I went with the SERT after an abortive attempt with the Fi-2000, and couldn't be happier. Have a thunder header and SE heavy breather. 81hp/103tq
2012 FLTRX
Triggs is offline
post #8 of 26 (permalink) Old 02-07-2014, 07:18 PM
Ohiobellboy's Avatar
My bike came with a SERT when I bought it. I've downloaded the software but have not bought the cables to go with it. It just sits in the bottom of the saddlebag. It does have an auto tune feature from what I've nosed around but I'd rather leave it to someone that knows what they're doing with it.
A.K.A OBB
Ohiobellboy is offline
post #9 of 26 (permalink) Old 02-08-2014, 04:00 AM
sj01fltri's Avatar
I spoke to a local tuner on Monday,he very is respected as a tuner in our area,we talked cams ,comp,heads and tuners,he has for years always used SERT's,but he said that as of late he has been tuning with the TTS,he says it has a couple of features that the SERT dosent have,but he said the SERT is a great tuner,so after talking to him i will be going with the TTS.
sj01fltri is offline
post #10 of 26 (permalink) Old 02-08-2014, 07:32 AM
qkshift's Avatar
I have used the se tuner for years and have change upgrades in the motors during its use. I don't mind paying for a dyno tune to perfect the performance out of the bike
qkshift is offline
SE tuner and Power Vision tuner question bigshaqa *General Road Glide Discussions/Pictures 8 01-11-2015 09:35 PM
V&H Power Duals, Monster Ovals, SE Race Tuner,Heavy Breather BigWaterJim Intake and Exhaust 1 09-11-2013 12:23 PM
Enlighten me on SE Race Tuner! Donk ECM/Fuel Management systems 13 03-29-2013 03:27 PM
HD Super Tuner vs HD SE Street Perf Tuner mhud3780 ECM/Fuel Management systems 1 02-18-2013 10:00 AM
32107-01E SE EFI Race Tuner twowheel99 Classifieds Archive (3 months old+) 3 10-22-2010 07:30 AM
