What base map should I start with? - Road Glide Forums
post #1 of 1 (permalink) Old 02-17-2014, 07:58 AM Thread Starter
fragmentum's Avatar
My 2009 Road Glide is getting some major engine work done because it had a tight spot in the rods.
Besides new flywheel assembly and other parts, it is getting SE-255 cams installed and new piston rings. It is going to need some break in miles and tuning.
My question is what is the best choice for a base map to use for the break in mileage (500 to 1000 miles) when I get this bike back from the dealer??
I have a new SE Pro Super Tuner (32109-08C), cables and training DVD.
I am not concerned with squeezing every last drop of performance out of the new cams just yet but want an optimum map that will allow the rings to seat and cams with their new SE lifters to wear in initially.
If your not living on the edge, you're taking up too much room...
fragmentum is offline
15 RG A base model as base can be..... maddmoe Audio 9 03-15-2015 07:30 PM
Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut mitchdm ECM/Fuel Management systems 3 05-16-2014 09:31 AM
Anybody suggest a base map ammojeff ECM/Fuel Management systems 2 06-17-2013 10:43 AM
PC-V Base Map needed Hullhorr Map Section 0 10-22-2012 01:20 PM
Base map for SERT Too Short Intake and Exhaust 0 07-23-2012 07:40 AM
