My lack of dyno tune - Road Glide Forums
post #1 of 8 (permalink) Old 02-17-2014, 02:17 PM Thread Starter
faststan's Avatar
I have been looking into getting my bike dyno tuned and need more information from you dyno guys.
I have a Power Vision. That is a detachable unit. When a dyno tune is performed it seems to me that the instant changes achieved would tell me that the map in the ECU is what is being changed not some map in a detachable unit. If that is the case, why do tech's shy away from the PV? They look like they are watching the NASA moon landing when talking to them.
I hope someone will set me straight as I am confused.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #2 of 8 (permalink) Old 02-17-2014, 02:28 PM
skratch's Avatar
it's all in what tuner they are used to using. pv tuners are becoming more common, but they are still few in numbers.
skratch is offline
post #3 of 8 (permalink) Old 02-17-2014, 04:39 PM
ERod62's Avatar
Yep many using Power Commander V. For stage 1 auto tune work well for me. Was some where on the upper 80's hp and mid 90's on a dyno run before cam upgrade.
Sent from Motorcycle.com App
ERod62 is offline
post #4 of 8 (permalink) Old 02-17-2014, 05:05 PM
Redbeard77's Avatar
Check with Doc's Performance in Minneola.
Happiness is a warm motorcycle.
Redbeard77 is offline
post #5 of 8 (permalink) Old 02-17-2014, 06:07 PM
Triplej's Avatar
Doc don't do Power Vision.
Triplej is offline
post #6 of 8 (permalink) Old 02-18-2014, 01:52 PM
ERod62's Avatar
Nope Doc only use TTS but sure he will tune your bike to run at its best. Am very please with his work wish if knew about him sooner would save second tune.
ERod62 is offline
post #7 of 8 (permalink) Old 02-18-2014, 08:27 PM
The Power Vision flashes the ECM like TTS or SEPST.
The PV is a good unit, play with it, learn how to use it, and it will accomplish anything that any of the other tuners out there will.
HeatWave is offline
post #8 of 8 (permalink) Old 02-18-2014, 09:11 PM Thread Starter
faststan's Avatar
I don't have a problem with the PV. I'm wanting to get some information regarding dyno tuning. It seems to me that any off bike tuner (not piggy back) would be a PITA if the actual tuner had to be used. It would be changing the map in the tuner and downloading it and make a run. Then changing the map in the tuner ad nauseum.
The thing that brought this up was my change in exhaust from 2-1 to 2-2. I emailed Jaime to find out if I would need a new map and he responded that I could do a couple autotune (Basic) and be good to go. I talked with Carl at Carl's speed shop on Beach Street and he said "sure" they could dyno the bike but when I called to talk with the actual guy that does the dyno tuning he was very put off. He said he would have to call DynoJet to get some information and he hasn't called in over a month.
faststan is offline
Lack of windshields for 2017 Road Glide dshudson *General Road Glide Discussions/Pictures 14 02-10-2017 09:10 AM
Lack of umpfff RustyNutz Intake and Exhaust 0 07-25-2016 09:41 AM
Lack of stereo volume Brian C Audio 8 08-13-2011 09:48 AM
Front Brakes (or lack of) roadglide77706 Troubleshooting for Road Glides 4 05-28-2011 10:20 PM
