I prolly need an ECM upgrade - Road Glide Forums
post #1 of 9 (permalink) Old 06-05-2010, 05:14 PM Thread Starter
SKULLZ's Avatar
After 4K miles, my night stick is showing signs of running lean. I need to go cheap, what are my options? My service manager said there is no upload like there was on my 05 king.
SKULLZ is offline
post #2 of 9 (permalink) Old 06-12-2010, 06:50 AM
Sancho's Avatar
Try buying a fuelpak off Ebay. You can get the map for it off the web site. That would be about the cheapest way to go but every Nightstick I've seen has turned brown.
Sancho is offline
post #3 of 9 (permalink) Old 11-19-2010, 10:56 AM
roadgliderick's Avatar
Send a message via Yahoo to roadgliderick
a friend of mine did a 103 down load and he said it helped alot.
2011 roadglide firemist orange carlini 17 inch eval bars, C&C solo seat, paugho true duals with thunder header slip ons , oil bud oil cooler, cool sac grips, alpine cda 105 head unit, alpine type r speakers with alpine 2150 digital amp,stratum timer cover derby cover and a/c cover sinister wheels 21 up front 18 rear woods 555 cams with adjustable push rods and tmax tuner. bad dad front wrap and bad dad rear summit fender with hide-a-plate and flush mount rear LEDs arlen ness big bags.
roadgliderick is offline
post #4 of 9 (permalink) Old 11-19-2010, 02:07 PM
DED HD's Avatar
I bought the PCV from Fuel moto and it came with a free map.
Helped out a lot!
'10 Red Custom:
DED HD is offline
post #5 of 9 (permalink) Old 11-19-2010, 05:56 PM
Towerhog
Guest
Posts: n/a
You could always try the Terry Components TV3. Seems to work rather well.
post #6 of 9 (permalink) Old 11-19-2010, 07:28 PM
your dealer is wrong. There is a stage 1 download. I have one in my 2011 RGU with stage 1 aircleaner and slipons.
jeff is offline
post #7 of 9 (permalink) Old 11-19-2010, 07:50 PM
SafetyMan's Avatar
Before I spent $200 for a dealer download, I'd at LEAST buy a V&H Fuelpak for $250.
I hate to say it, but a $20,000+ motorcycle ain't the place to go cheap.
$400 +/- for a TTS is pretty cheap, in comparison to the cost of an engine.
ANY tuner, whatever your pref, PCV, SERT/SEST whatever is worth the money.
WSFFWS
2B1ASK1
SafetyMan is offline
post #8 of 9 (permalink) Old 11-20-2010, 09:57 AM
ncbeast's Avatar
Cheapest you could go would be IEDs from nightrider.com....I have not every used them but it would be the cheapest, best way to go would be PCV from FuelMoto.
Greg
2008 Road Glide/ABS
Dark Blue Pearl
ncbeast is offline
post #9 of 9 (permalink) Old 11-24-2010, 09:22 AM
dres22's Avatar
I use the IEDs. This is an inexpensive way to go and has many benefits. Easy to install. No dyno tuning needed. Get most of the performance benefits of stage one upgrades. It will richen up the closed loop air/fuel ratio to 13.8 to 1 from 14.7 to 1. This lets the bike run cooler and brings exhaust temps down. The motor running stock in the closed loop is likely the cause of the nightstick changing color, not the open loop stage that actually is tuned pretty well stock. EPA mandates do not apply to open loop throttle conditions so HD can and does tune that operation much richer in the air/fuel ratio. A down load or fuel pac will do little to nothing to change the closed loop air/fuel ratio. IEDs are not a real performance tunner and will not max out your motors power but the bike will run great, trouble free, cooler, and is a good option for someone not looking to spend a lot to get max performance from a stock or stage one bike.
Frank Layden, Utah Jazz president, on a former player:
"I asked him, 'Son, what is it with you? Is it ignorance or apathy?'
He said, 'Coach, I don't know and I don't care.'"
dres22 is offline
Do I need a tuner, or can I have the Delphi ECM reflashed? EdMac *General Road Glide Discussions/Pictures 4 08-01-2015 10:19 AM
Miley Cyrus prolly ain't gonna be on no Hillary campaign posters............ outcast1 General Off-Topic Discussions 10 03-01-2014 06:49 PM
Prolly the loudest i've heard baghrd Audio 10 09-08-2013 02:35 AM
Ecm calibration upgrade for 2007 big twins mea4dxl ECM/Fuel Management systems 3 11-18-2011 09:34 PM
Newbe has an Exhaust/ ECM Feul Mgmt Question whataglide ECM/Fuel Management systems 3 08-17-2010 01:31 PM
