Need a 117 base map for pcv tman 625s and worked heads any 117 mapwill work using aut - Road Glide Forums
post #1 of 4 (permalink) Old 03-06-2014, 08:43 PM Thread Starter
mitchdm's Avatar
Need to map for Power Commander 5, 117, tman 625s, type b heads, any 117 will work, we are using Autotune, this is for a forum members bike.
mitchdm is offline
post #2 of 4 (permalink) Old 03-06-2014, 10:10 PM
DynoJet is already set up at the Daytona Speedway for Bike Week
HeatWave is offline
post #3 of 4 (permalink) Old 03-07-2014, 05:19 AM Thread Starter
mitchdm's Avatar
Awaiting a response
mitchdm is offline
post #4 of 4 (permalink) Old 05-16-2014, 09:31 AM
Deadstroke's Avatar
Did you ever get your tune? If not PM me and ill send you one.
Deadstroke is offline
15 RG A base model as base can be..... maddmoe Audio 9 03-15-2015 07:30 PM
Luggage rack "base washers" - anyone using? HellInABucket Equipment-RG 12 02-24-2015 10:36 PM
Dragos ported heads tman 555 stock SCS-4 pipe DragoBikeWorks Dyno Results 7 10-30-2013 07:55 PM
Need map for 10' 96" drags 2into1 tman tq555 Jrod95 Map Section 1 09-22-2013 03:38 AM
Need Pcv map for 2010 FLTRX Garcou ECM/Fuel Management systems 4 10-20-2010 05:41 AM
