PCV and auto tune question - Road Glide Forums
post #1 of 4 (permalink) Old 03-09-2014, 06:13 AM Thread Starter
toogood8p's Avatar
After installing a PCV and auto tune with wide band sensors, do you need to first download a map that is close to your setup or will the auto tune make enough adjustments to get the fuel mix right?
If so, after how long or many restarts?
Bear, Prez, Kindred MC
13 FLTRX - Candy Orange - Daymakers, Custom Dynamics - LED turn signals, Kuryakyn Scythe mirrors, Iron Aces bracket, X-grip, floor board extensions, custom sundowner seat, black KW 8", PCV, auto tune, Stage 1 AC, Drago H-pipe, 4" Dragula mufflers.
toogood8p is offline
post #2 of 4 (permalink) Old 03-09-2014, 07:30 AM
mitchdm's Avatar
The short answer is no. I have actually 0 mapped and set the afr's for the autotune, make sure autotune is enabled, and accept trims. First on short rides then on longer ones. I did increase my ability to adjust in configure to 50 from 20. This is a little more work but my 113 has never been on a dyno and runs great. The map is pretty much dead on now and fuel trims in autotune are single digit. But this does take some time. It is not how many restarts but really how many miles.
mitchdm is offline
post #3 of 4 (permalink) Old 03-09-2014, 12:37 PM
mocotom's Avatar
The advantage to having a base map that is close to your set-up is the amount of riding needed to get the tune where it needs to be. As mitchdm pointed out it is not an absolute necessity but greatly reduces the amount of tuning required.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #4 of 4 (permalink) Old 03-09-2014, 01:52 PM Thread Starter
toogood8p's Avatar
Thanks guys
To auto-tune, or not to auto-tune Magnum ECM/Fuel Management systems 12 08-27-2014 06:25 PM
PCV with auto tune and CFR slip ons. WilD DawG ECM/Fuel Management systems 0 10-11-2013 02:04 PM
auto tune vs no auto tune Jacket4256 ECM/Fuel Management systems 18 06-01-2013 08:12 PM
PCV Auto Tune vs Dyno ODA CDR (RET) Intake and Exhaust 2 10-05-2011 11:37 PM
Installed a PCV auto tune yesturday. JTultra Road Glide Specific Discussions 7 09-10-2011 02:16 PM
