School me on these fancy "tuners" please? - Road Glide Forums
post #1 of 38 (permalink) Old 03-13-2014, 01:39 PM Thread Starter
kyle31490's Avatar
So I have a new to me 2010 RGC with the 96. Right now it has Screaming Eagle slip-ons, stock A/C, and Im pretty sure stock head pipe. The baffles are apparently in the slip ons as I can see them pretty good, hanging out a bit from the ends.
I want a louder exhaust, a nice looking A/C, and an engine that might run a bit cooler.
I honestly don't want a tuner or flasher or ECMPNFUJGBSJNSZ whatever thingy majiggy. I try to stay out of high tech electrical things
However, I see I will need one of these contraptions. Ive done some searching, but still not seeing much on basic info on them. I do not wanna go to the dealer and tell them to piece together an exhaust, A/C, and tuner for me since im sure they will charge $9,999,999,999 to do so. I just want all three components to work together nicely, sound decent, and look decent.
Where do these things go on the bike? Are they hard to install and/or wire? Do any of these tuners work with all set ups? How do you adjust it? Are there automatically adjusting ones? Am I making this more complicated than it really is? Help?????
Thanks all.
kyle31490 is offline
post #2 of 38 (permalink) Old 03-13-2014, 02:14 PM
Well you will need a tuner if you do air intake and exhaust mods and future mods. The first thing I would check into is did the previous owner have a SERT (Screaming Eagle Race Tuner) installed at some time, a check at the HD dealer or with the previous owner may be able to tell you. If a SERT was used on your bike the previous owner should have had it in the bike when he sold/traded the bike.
Only 1 SERT can only be married to 1 ECM so if your bike had the SERT you will not be able to use another SERT.
The good news is most aftermarket tuners will piggy back to your ECM and they will work great. You should look into tuners that do more then just AFR adjustment look into tuners that can make timing adjustment as well.
Some tuners are like the SERT are only used when the bike is tuned and it is not permanently attached to the bike other tuners have to stay on the bike. Power Vision makes a good unit and is popular with many members on the forum.
There are a lot of threads on tuners so doing a search on the forum will give more info
post #3 of 38 (permalink) Old 03-13-2014, 02:45 PM Thread Starter
kyle31490's Avatar
Searching still now.... Not really understanding, but searching. Hoping it all falls together in my mind haha.
So is this "SERT" what is considered a download?
Can it be erased? Will the dealer know for sure if its on there?
post #4 of 38 (permalink) Old 03-13-2014, 07:43 PM
Curt33's Avatar
In all honestly I can't tell you to much about the SERT. But for me I found the manufacturers web sight my best source for info. Def look at power vision and Pcv. Pull up deferent manufacturers web sites and compare them head to head. They will go into great detail with long list of what they are capable of and as long as you can follow directions and you enjoy tinkering on your bike doing all your bikes upgrades will be a fun project. I would recommend power vision. I don't personally have it on my bike YET but I helped my friend install it and set his bike up. It is very user friendly and performs well. Also gives you the option to leave it on bike or unplug and forget it so to speak. Def look at how much you want to spend and check out some of the info the manufacturers have to offer. Sorry for the long drawn out answer lol
When in Rome. Do as the Romans do
12 rgc. With lots off goodies.
84 shovel head. I got bored so it's in pieces
Curt33 is offline
post #5 of 38 (permalink) Old 03-13-2014, 08:32 PM
skratch's Avatar
technically, the sert doesn't exist. that was an older product that hd had discontinued their relationship with. they then came out with their 'street tuner' (which is still epa compliant), and the 'super tuner' (the sert replacement).
but there are also several other products, the original mfg of the sert, now makes the tts. then there is the thundermax. and some others, not so well known.
before you make any decisions, study up on the capabilities of each unit, and what you are looking for. its a shame to buy a $500 tuner if all you want to do is flash it once for stage 1 and then forget about it. but, its also really the best way to go about it. sure there are other fixes that 'sorta' work, but if you spend the money once and it only hurts for a minute and you won't have to worry later on down the road if you change something. unless of course you are the type to insist on a dyno tune after each change.
skratch is offline
post #6 of 38 (permalink) Old 03-13-2014, 09:11 PM
fragmentum's Avatar
kyle31490,
The information my learned forum members have written here is mostly correct, but with all the acronyms and lack of detail, I can imagine you are still mostly confused.
With the modifications you are making to your motorcycle engine, you need to adjust the Electronic Control Module (ECM) by having the data inside of it adjusted. There are two methods. Harley-Davidson sells a couple devices that connect up you ECM to a computer to download a new data map that will provide the needed changes for the hardware you have installed (exhaust, high flow air cleaner or what have you). There is a less expensive device called the Screamin' Eagle Street Performance Tuner that you or the dealer can use to upload the latest ECM calibrations to your bike. The second device is the Screamin' Eagle Pro Super Tuner that allows you or anyone qualified to upload an ECM calibration to your bike but also fine tune all the parameters of your add-on parts.
There are other aftermarket devices as well that will 'write' directly to your ECM and are not permanently attached to your bike when the calibrations are completed (like the Harley tuners) and there are others that 'piggy back' on to your ECM to make changes to the data used by your engine and stay connected to your bike.
Don't discount what your Harley dealer can do for you and have them explain the options and costs to you. That is only fair by any business. Don't assume that they are out to cheat you or over sell you. Get your information first, be informed, then do your shopping, even with multiple dealers. You will be able to tell who has your best interests at heart.
You don't seem like the rider to tackle the tuning of your bike yourself, but are smart to ask questions here and seek guidance.
Good for you and good luck.
If your not living on the edge, you're taking up too much room...
fragmentum is offline
post #7 of 38 (permalink) Old 03-13-2014, 10:49 PM Thread Starter
kyle31490's Avatar
That's the kinda answer I needed! Still learning but that's a good base. Thanks!
I really only want an exhaust and a/c haha.
post #8 of 38 (permalink) Old 03-13-2014, 11:20 PM
Check out http://www.fullsac.com/
their stuff is pretty much expandable, if you should feel the need in the future.
If you are sure that you are going to stay with pipe / ac then a fueler will work just fine. http://fp3.vanceandhines.com/
HeatWave is offline
post #9 of 38 (permalink) Old 03-14-2014, 12:43 AM
kyle31490, I see your from pa like myself. check out throttle city. chuck is one of the best engine builders and tuners out there. hes based right outside philly. But he has a mobile dyno and hits most of the pa events and some of our dealers open houses and partys. He will sell you a tuner install it and tune your bike on his dyno right in front of you. it ushally draws a crowd too.
pontoonman is offline
post #10 of 38 (permalink) Old 03-14-2014, 09:40 AM
fragmentum's Avatar
I am glad my explanation was helpful. My engine needed major work done this winter because of failure of the flywheels. My Road Glide is bone stock in the engine/transmission areas except for a free flowing air cleaner. Because the cams in my motor were showing signs of the cam lobes hard surfacing starting to wear adversely, we decided to upgrade them as well to SE-255 cams. That upgrade now requires the ECM to be re-tuned so I bought a Screamin' Eagle Pro Super Tuner (SEPST). I had the dealer that did the engine work download the closest base MAP available for my motor and 'flash' that MAP to my ECM with the SEPST. I will further fine tune this MAP to my bike when the weather is ride-able. I am relatively new to this process as well, but I have been doing a LOT of reading and research on the subject here on this forum as well as several others.
There are a lot of independent (Indys) tuners and businesses out there that can assist you as well, especially on the East Coast. Seek out recommendations from those here and contact those folks with your questions. Get their advice and counsel and take advantage of those that offer the same suggestions.
take me to school jaysrgu Suspensions 3 03-02-2014 08:10 PM
Nothing fancy but I love this bike :) ReaperAA Road Glide Builds-Document your builds HERE --NEW 10 04-03-2013 01:37 PM
Fancy exhaust tips Torquey Intake and Exhaust 22 12-27-2012 04:06 PM
Explain tuners to me please palmpalm ECM/Fuel Management systems 10 09-29-2012 06:34 PM
Please, Please, Please don't do this... cnidog Safety Area 13 09-01-2012 09:51 AM
