"The bike only pings from 2500 rpm up at partial throttle" - Road Glide Forums
post #1 of 11 (permalink) Old 03-22-2014, 04:43 PM Thread Starter
Mountainman's Avatar
Send a message via Yahoo to Mountainman
Thumbs down "The bike only pings from 2500 rpm up at partial throttle"
"The bike only pings from 2500 rpm up at partial throttle, you need to downshift and get more rpm to accelerate with partial throttle"
Service MANAGER explaining to me that his dyno guys are doing ok.....
How long have the 103's been running with 255's? 10+ years?
New candidate for dumbest thing a Harley Manager has ever said to me... :emoGroan:
2013 FLTRU Big Blue Pearl:RB Racing LSR Spyder, SE255's (110/95), SERT, Boyesen Power x, DK intake vents,3"tank lift, t-pack relocator, Outlaw oil filter, Slipstream htd grips, l-s mirrors,adj backrest, 3t derby, sancho's wings, Ward's 160* thermostat, BigSky fans, Liquid Moly 10w-60, Rdeline VTwin Heavy Shockproof, B&M Trickshift, Burly ez clutch
Mountainman is offline
post #2 of 11 (permalink) Old 03-22-2014, 05:18 PM
faststan's Avatar
I've got SE 255's in my 103. No ping, just go. So, it can be done. I'm using PV tuner with a map from Jaime at Fuel Moto.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 11 (permalink) Old 03-22-2014, 05:24 PM Thread Starter
What?
Can't be, the HD service manager told me so!
post #4 of 11 (permalink) Old 03-22-2014, 07:45 PM
hook's Avatar
Hope you get it resolved. Sounds like you know your stuff. Good luck!
2011 RGU
hook is offline
post #5 of 11 (permalink) Old 03-22-2014, 07:53 PM
DOOFUS HD must have opened a Service Mgr certificate program, no mention of a spinach additive for and extra $100
reds4 is offline
post #6 of 11 (permalink) Old 03-22-2014, 08:13 PM
GlideShark's Avatar
20 lashes for your blasphemy!
-- DOOFUS HD Propaganda Minister
Sent from Motorcycle.com App
GlideShark is offline
post #7 of 11 (permalink) Old 03-22-2014, 10:06 PM
Typical Harley Dealer BS
They all seen to spout the same crap when they don't know how to fix something properly. I was told the same story with my bike. Took it to different shop and they were able to do the impossible. Maybe someone can suggest a good shop in your area.
Reddobe1 is offline
post #8 of 11 (permalink) Old 03-23-2014, 12:47 AM
[QUOTE=GlideShark;1699521]20 lashes for your blasphemy!
Tongue lashes gladly traded for payment
reds4 is offline
post #9 of 11 (permalink) Old 03-28-2014, 05:39 AM
Hi all from Russian North!!!
There is only TWO things for delete pinging (I prefere detonation-knock determination as an automotive diagnost)
1) richness AF mixture(first of all if I see knockin I made AFR more rich to 11.5-12.5AFR in this area)
2) ignition retardation
For my tuned Mitsubishis its work!!!
Thus - you need recalibrate your maps.
Sorry for my poor english.
Lukidj is offline
post #10 of 11 (permalink) Old 04-06-2014, 09:22 PM Thread Starter
Smile Problem solved!
Roy at Bumpus Whitten Road of Memphis totally saved the day and has made the bike run BEAUTIFULLY!
110/95 sae 5 dyno
Loaded with 450# of driver, passenger and gear the bike pulls cleanly away from 1900 rpm.
Acceleration is brisk, deceleration is clean and pop and gurgle free.
The bike is SMOOTH!
2500-3000 rpm vibration mouser58 Engine Related 1 11-15-2016 02:59 PM
2010 rg throttle hiccups at around 1900 rpm scotrod Troubleshooting for Road Glides 2 12-03-2011 10:00 AM
2500 Miles behind the Iron Curtain BlackBetty11 Road Trip Discussions/Stories/Pictures 3 06-23-2011 03:52 PM
