thundermax cruise control issues - Road Glide Forums
post #1 of 18 (permalink) Old 03-26-2014, 08:38 PM Thread Starter
ok so I just installed a used thundermax tuner and dragos pipe frank was great supplied the base map.
well after all said and done I lost cruise control six gr light lights up
has anyone had this issue?
Saturday I will try stock ecm to see if cruise works as it did prior to install of t max
thanks
bill
im sure this thread is in wrong spot
milkman48 is offline
post #2 of 18 (permalink) Old 03-26-2014, 09:33 PM
faststan's Avatar
Did you do anything else to the bike at same time? Do you brake lights work as advertised? Did you unplug the brake switches for any reason?
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 18 (permalink) Old 03-26-2014, 09:38 PM Thread Starter
just pipe tuner and air cleaner checked fuses brake lights switches and conections
im going to try plugging stock ecm in tomorrow see if that brings it back
post #4 of 18 (permalink) Old 03-26-2014, 10:51 PM
Lost my cruise when I had power commander installed. Was some kind of software issue. Had to take it back for another download
Glides10 is offline
post #5 of 18 (permalink) Old 03-26-2014, 10:55 PM
Curt33's Avatar
I'm curious to what you fined out. I should be receiving a new dragos system and t max from frank here soon. Never heard anything about this issue
When in Rome. Do as the Romans do
12 rgc. With lots off goodies.
84 shovel head. I got bored so it's in pieces
Curt33 is offline
post #6 of 18 (permalink) Old 03-26-2014, 11:09 PM
PFWiz's Avatar
Give Frank a call. Frank always stands behind whatever he sells...
PFWiz is offline
post #7 of 18 (permalink) Old 03-27-2014, 05:25 AM Thread Starter
I bought the set up used and frank has been more than helpful by supplying a base map but in reality he's probably crazy busy right now so ill try. Forum and tmax. Before I hit him up. Or wait till fall to get it up to him
post #8 of 18 (permalink) Old 03-27-2014, 08:12 AM
Louisville Joe's Avatar
You say you have a used Thundermax. I don't have details but I have read somewhere that some of the older Thundermax units had a problem with cruise control. My thundermax is less than a year old and it doesn't interfere or cause any problems when I use my CC. You may want to phone Thundermax.
Louisville Joe is offline
post #9 of 18 (permalink) Old 03-27-2014, 09:59 AM
Did you hookup you PC and see if the T-Max module is running the current firmware and software?
post #10 of 18 (permalink) Old 03-27-2014, 04:07 PM Thread Starter
Yes all is up to date. I need to send in a run report. To move ahead.
2012 Road Glide Cruise Control issues Blademn Controls & Handlebars 3 08-11-2017 08:43 AM
RG cruise control CEL issues Diverrick *General Road Glide Discussions/Pictures 3 09-05-2015 08:04 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
Thundermax cruise control ameleo ECM/Fuel Management systems 8 07-30-2012 06:11 PM
Cruise Control issues Cheesyrider Controls & Handlebars 4 04-05-2012 04:37 PM
