Hard starting rg - Road Glide Forums
post #1 of 22 (permalink) Old 03-27-2014, 03:47 PM Thread Starter
Hard starting rg
I have a 02 rg with 95" kit ,gear driven cams, thunderheader and s.e. race tuner
Recently became very hard to start , turning over good , batt. Good . It just keeps chugging and backfiring through breather and pipe , acts like not enough spark, can smell fuel when backfiring so it seems to be getting plenty of that. Did basic test of coil came out good , does this hot or cold starting . ECM? , any feedback appreciated. Good starter ,batt. And reg. stator checks out good. Thnx all
Spikeglide is offline
post #2 of 22 (permalink) Old 03-27-2014, 04:11 PM
Hullhorr's Avatar
I'm not familiar with the SE race tuner, but is it possible to reset it? I have a Thundermax and any disruption to the electrical system requires me to initialize the map again to the bike.
I would also check for a blown fuse, and also disconnect the ECM and put dielectric grease on the connection. Could just be moisture from sitting.
2009 FLTR MOP
Hullhorr is offline
post #3 of 22 (permalink) Old 03-27-2014, 06:08 PM
Of course you have pulled the plugs? make sure the ceramic isn't cracked and gaped correctly, ohm the wires too
reds4 is offline
post #4 of 22 (permalink) Old 03-27-2014, 07:38 PM Thread Starter
Yes new plugs and wires ohmed out good, unplugged ECM, dis conned batt. I'm out of ideas, sometimes it fires right up , then next time it almost kills batt. I guess I'm gonna have to put in for diags., I also checked for codes on the speedo self diag. Check , all we're clear , frustrating I hate puttin in the shop, thanks for all the ideas!
post #5 of 22 (permalink) Old 03-27-2014, 10:21 PM
Perlinal's Avatar
I had the exact same issue and got many of the same replies. At the end of the day it turned out to be my compensator even though it wasn't typical symptoms. Issue completely gone now
Alan
Perlinal is offline
post #6 of 22 (permalink) Old 03-27-2014, 10:31 PM
rageglide's Avatar
EFI or Carb?
2012 fltrx
rageglide is offline
post #7 of 22 (permalink) Old 03-27-2014, 11:19 PM
tdkkart's Avatar
First, pull the ECM fuse for 30 minutes or so to reset things, helps a surprising number of issues.
Head temp sensor is worth adding to the list of things to check, especially since it's a cold start issue.
The other one is the crank sensor, they've been known to get flaky and signal sometimes and not others, being an '02 makes it even more likely.
tdkkart is offline
post #8 of 22 (permalink) Old 03-28-2014, 06:15 AM Thread Starter
Efi
post #9 of 22 (permalink) Old 03-28-2014, 09:28 AM
DED HD's Avatar
Possibly need a new heavy duty starter?
'10 Red Custom:
DED HD is offline
post #10 of 22 (permalink) Old 03-28-2014, 11:04 AM
CNMTurner's Avatar
First thing I though of when said backfiring through AC.. or possible Crank position sensor..
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
Hard starting problem Tour Rider Engine Related 9 06-14-2016 12:10 PM
hard starting, poor idle, gas smell mack1968 Troubleshooting for Road Glides 5 02-05-2016 09:17 AM
How hard is too hard? tlottman *General Road Glide Discussions/Pictures 11 08-28-2015 06:42 AM
12 Ultra Classic hard lowers on 08 RG? Sethjamto Equipment-RG 6 02-27-2014 07:31 AM
Hard starting when hot fat boy ultra Troubleshooting for Road Glides 1 08-24-2012 07:54 PM
