ThunderMax ECM with V&H Power Duals - Road Glide Forums
post #1 of 8 (permalink) Old 03-31-2014, 03:17 PM Thread Starter
I'm considering buying the ThunderMax wideband ECM. I have Vance and Hines Power Duals head pipe. Does anyone else have this combination? It appears that I will have to have new 18mm bungs installed in the head pipe. has anyone done this already? If so, what is your advice? I appreciate the help.
Jeff York
Jeffman is offline
post #2 of 8 (permalink) Old 03-31-2014, 04:58 PM
Curt33's Avatar
It all depends on what year your rg is. If you have a 09 then your pipe should already have 18mm bungs. If it's newer then you have 12mm and you will need new bungs installed.
You could always sell your current head pipe and purchase a 09 head pipe and then you will have factory 18mm bungs. Sense you will have to take your exhaust apart anyway do to needing to upsize your bungs this would be a route you could take.
Sense you already have a aftermarket head pipe with 12mm I would look into power vision but that's just my .02 cents.
I have dragos full system and t-max on the way but if I were in your shoes and assuming that your v&h is set up for 12mm, look at power vision.
When in Rome. Do as the Romans do
12 rgc. With lots off goodies.
84 shovel head. I got bored so it's in pieces
Curt33 is offline
post #3 of 8 (permalink) Old 03-31-2014, 05:01 PM
Curt33's Avatar
Tell us more about your bike. Is exhaust mounted or waiting to be installed. Do you have hi flow a/c. What year is it. What are your future plans for it. And do you have plans for motor builds in the future.
Curt33 is offline
post #4 of 8 (permalink) Old 04-02-2014, 09:43 AM Thread Starter
My RG
I have a 2012 RG. The head pipe and exhaust are already mounted. It appears I have the 12mm bungs. I do plan on upgrading to a phase 2/3 kit sometime in the next year.
Jeff York
Jeffman is offline
post #5 of 8 (permalink) Old 04-02-2014, 10:13 AM
The T-Max is a good tuner and it will be a good tuner for your future performance upgrades.
Yes you will need the 18mm O2 sensor bungs but you can install them yourself if you know how to weld, if you don't know how to weld it won't cost much at a welding shop to have the 18mm O2 bungs welded in.
The O2 bungs are cheap and you can get the straight bungs at any auto parts store but the angled bung are a little harder to find and you may need to order them, I would think you would need the angled bungs so the O2 sensors would fit without hitting anything.
There are aftermarket head pipes that have both the 12mm and the 18mm O2 bungs and all you need to do is plug the bungs that you do not use.
post #6 of 8 (permalink) Old 04-02-2014, 12:46 PM
Roadglide1's Avatar
Thundermax
All I can say is that my bike runs sooooo much smoother now. I'm now a true believer in Thundermax. I have a 2012 RG with a D&D headpipe/exhaust. You'll be very satisfied with the tuner as long as your exhaust fits your motor set up.
2012 RG: 120R motor, Thundermax ECM, D&D Boarzilla header/exhaust, Top Shop rear fender/bags, Lepera seat, Pure Black Paint by Vico's, JL sound system by John @ SAS Customs, Progressive Shocks( -2/944's), Trinity Wheels 21/17, Hawg Halters forks/forward controls. Bars by BR's Customs, Security:Bad-Ass Police K-9. etc......
Roadglide1 is offline
post #7 of 8 (permalink) Old 04-02-2014, 12:57 PM
Bluchevypick's Avatar
You can just take it off and have them welded. You will not need to order anything as the Thundermax will come with the bungs needed and a very detailed description on where to place the bungs at. The Thundermax is the way to go.
Bluchevypick is offline
post #8 of 8 (permalink) Old 04-02-2014, 01:08 PM
I never got O2 bungs with my T-Max module when I got it new. My Bike is a 08 and it already has the 18mm O2 bungs so may be that is why I didn't get them.
Tags
18mm bung , thundermax , true duals
Thundermax autotune ecm part # 309-362 for 08-13 touring RIDERED67 Sold 3 09-09-2013 08:36 AM
V&H Power Duals or Dresser Duals? RTWRK Intake and Exhaust 35 08-11-2013 06:21 AM
Zippers ThunderMax ECM and Closed loop system. Big Red Glide ECM/Fuel Management systems 4 12-31-2012 04:18 AM
V&H Dresser Duals Vs. Power Duals? HoboCoastie Intake and Exhaust 2 01-31-2012 06:26 PM
