thundermax - Road Glide Forums
post #1 of 10 (permalink) Old 04-11-2014, 10:13 AM Thread Starter
thundermax
I installed a thundermax on my 12 rg it works great, except to re start after the bike is wormed, it turns over & over before it starts. if I take my finger off the start button and hit the start button again it starts right up. any buddy else have a similar problem ??????
craig demel is offline
post #2 of 10 (permalink) Old 04-11-2014, 12:18 PM
Bluchevypick's Avatar
I have learned with mine that its best to let the engine light go off before you try to start. This lets the thundermax run all its checks and get primed.
Bluchevypick is offline
post #3 of 10 (permalink) Old 04-11-2014, 01:10 PM
Ok, lol I don't normally mess with spelling mistakes, but I thought the bike being "wormed" is kind of funny and a first for me. BTW, I agree with waiting for a few seconds after turning the switch before hitting the start button.
Sent from my SPH-L710
post #4 of 10 (permalink) Old 04-11-2014, 01:21 PM
Louisville Joe's Avatar
Yep, very similar problem here and I also have a Tmax. For cold starts I hit the start button for a second (as soon as the red light goes off) but I don't hold it cause I know it ain't gonna start--unless maybe I let it crank for a lengthy period and I don't want to do that. Then I hit the start button the second time and it fires right up. Really warm starts, like I only shut it off long enough to gas up, as soon as I hit the start button it fires right up. But...., if it was shut off for the time it took me to drink a coffee and smoke a butt, then I know it ain't gonna fire so I hit the start button once, then a second or two later I hit it again and it fires.
Louisville Joe is offline
post #5 of 10 (permalink) Old 04-11-2014, 02:03 PM
eme56's Avatar
I've got a 2005, so the software may be different for the older bikes, but on the basic settings window, you can change the "Initial Fuel Pulse" and the "Cranking Fuel" to eliminate the starting problems you are talking about.
The "Initial Fuel Pulse" determines how much fuel is sprayed by the injectors when the key is first turned on.
The "Cranking Fuel" will lean or richen the cranking fuel mixture.
After a little experimentation with these settings, Penelope explodes into life on the first hit of the starter button, from 25 - 105 degree weather, or after sitting in the garage for 5 months all winter. It doesn't matter if she's ice cold or only been shut down a few minutes.
So check the manual for your T-Max version and try some minor changes to see if it helps.
2005 FLTRI Black Cherry, 95" Big Bore, Thundermax w/Auto Tune, V&H Dresser Duals w/Klock Werks SS, Andrews 26 Cams, SE Stage 1 intake, SE OD/6 Speed, Wards FCS cooling fans, Krome Werks Stretch Heritage +2 bars, Progressive Monotubes, 444's, & Touring Link, Michelin Commander II's, 14.5" Madstad, Lowers with Classic Motorcycle Vents, detachable King Tour Pack, Daymakers
eme56 is offline
post #6 of 10 (permalink) Old 04-12-2014, 10:09 AM
Have you used the automap yet? After 4 or 5 riding sessions you should hook in your PC and run the automap. A riding session is considered riding the bike for 25 to 50 miles then turning the bike off when you restart the bike you will begin a new riding session. When you run the automap the module will read and learn your fueling offsets and make adjustment as needed. You should do a automap 3 or 4 times for the best results.
You can also do a idle tune which should be done when putting in a new base map or before you start the auto map.
Remember the T-Max will only auto tune the AFR and it will not auto tune timing adjustments, if any timing adjustments are needed they have to be done manually.
If your problem continues you should do a DATA COLLECTION and send it in to T-Max support with a discription of your issues.
post #7 of 10 (permalink) Old 04-12-2014, 12:16 PM
Hullhorr's Avatar
Do what Mark suggests in his last sentence.
I had the same issues with mine. I was getting ready to do as Mark suggested above, but when I opened the Thundermax program on my computer a notification popped up and said the map I was using had been updated. I downloaded the revised map and I no longer have any hard start issues hot or cold.
2009 FLTR MOP
Hullhorr is offline
post #8 of 10 (permalink) Old 04-13-2014, 12:33 PM
Roadglide1's Avatar
thundermax
...I do notice that every now and then, my bike will hiccup on cold start-ups with the Thundermax. however, I must admit I haven't dialed it in since I installed it 3 weeks ago. The one big difference I noticed is that my motor runs so much smoother and has a nicer exhaust note. The throttle response is also lightning quick. Overall, I very happy...
2012 RG: 120R motor, Thundermax ECM, D&D Boarzilla header/exhaust, Top Shop rear fender/bags, Lepera seat, Pure Black Paint by Vico's, JL sound system by John @ SAS Customs, Progressive Shocks( -2/944's), Trinity Wheels 21/17, Hawg Halters forks/forward controls. Bars by BR's Customs, Security:Bad-Ass Police K-9. etc......
Roadglide1 is offline
post #9 of 10 (permalink) Old 04-28-2014, 06:23 AM
I am not a tuner/tech by any means but have a Tmax on my '11 RGC with Dragos pipe and SE heavy breather and cams. Base map from Dragos was real good and bike ran smooth. Was down in Daytona and went to the Zippers tent and paid $50 for a 'check-up', this was back at Biktoberfest. The tech downloaded new updates/software, checked how the bike had been running and tweeked a few things. Bike ran nice before, now it pulls hard all over. I had 255 cams put in and always thought bike should have more low end...after re-tune I can see the benefit of them now, although still a mild cam. If you are ever at a rally and they are there, IMO it is worth the $ and let them ck out your bike.
UltraDune is offline
post #10 of 10 (permalink) Old 04-30-2014, 01:42 PM
thedrill's Avatar
+1 on that. My bike has never run better than with the T-max and for someone like me who changes things a lot it is the way to go. It is kinda picky on the start-up procedure.
2012 Road Glide Ultra, 1978 Honda XL125, 1992 Suzuki DR350
thedrill is offline
Thundermax TBW MakeARunMike ECM/Fuel Management systems 15 06-01-2011 10:07 AM
Thundermax on a stock 2010 RGC pab ECM/Fuel Management systems 18 12-22-2010 04:25 AM
Thundermax impression Rowdy ECM/Fuel Management systems 9 11-23-2010 09:27 PM
thundermax TBW roadgliderick ECM/Fuel Management systems 0 11-23-2010 12:36 AM
Zipper Thundermax Ranger58 ECM/Fuel Management systems 12 11-19-2010 10:26 AM
