PV E-10 Setting - Road Glide Forums
post #1 of 5 (permalink) Old 04-18-2014, 03:47 PM Thread Starter
PV E-10 Setting
Will the E-10 setting/function I just noticed when I updated
my PV be of any benefit ?
I noticed2-3 options, gas,E-10 and E-85.
Since most or all use the E-10 gas, but have been using the gas setting....
2010 FLTRX,103 Stage 2,FullSac 2-1-2, black ceramic CB/Intercom, Power Vision
websterdan is offline
post #2 of 5 (permalink) Old 04-19-2014, 09:39 PM Thread Starter
Power vision update
No one knows???
post #3 of 5 (permalink) Old 04-19-2014, 11:32 PM
tdkkart's Avatar
Originally Posted by websterdan View Post
No one knows???
I didnt even onow about it?? Where is it at and how do you get to it?? Its been a long winter, I updated all the latest software and updates a couple weeks ago but havent played with any of it.
tdkkart is online now
post #4 of 5 (permalink) Old 04-21-2014, 08:14 AM Thread Starter
Pv e-10
When you get tune and view sections, it will be on the right side where
AFR setting was/is.
post #5 of 5 (permalink) Old 04-21-2014, 01:49 PM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Unlike AFR, a Lambda is absolute. The toggle for gasoline, E-10 & E-85 allows you to select the AFR representation based on the stoichiometry for each given fuel. For example to find AFR for E-10 at a measured .98 Lambda you would use the following equation: .98 X 14.13= 13.84 AFR.
Changing this dropdown does not change the tune in any way, it simply changes how AFR is represented.
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
Speedo setting "r". Question for the techies BDMastiff *General Road Glide Discussions/Pictures 6 04-18-2011 11:35 AM
Setting weather alert . mdjr47 *General Road Glide Discussions/Pictures 4 04-14-2011 08:07 PM
Setting up a Forum? FLTRI *General Road Glide Discussions/Pictures 13 03-28-2011 03:10 PM
Need help setting up my wife's Road Glide NCTim *General Road Glide Discussions/Pictures 5 11-09-2010 11:27 AM
Setting it up the way I want it. DwayneInfo Aftermarket Accessories 8 03-23-2010 05:55 AM
