New tune needed after adding Cruise Control? - Road Glide Forums
post #1 of 6 (permalink) Old 04-22-2014, 08:28 AM Thread Starter
bear25314's Avatar
I ride a 2013 Custom. I also use a Power Vision. I plan on adding cruise control to my bike and i understand i will need a download from the dealer for the cruise control to work. Will the cruise control download effect my tune already downloaded in the bike and after I have the cruise installed can I still download future tunes to my bike without affecting the cruise download? Thanks
p.s. I plan on having the dealer install the Cruise.
bear25314 is offline
post #2 of 6 (permalink) Old 04-22-2014, 09:41 AM
2stangs8689's Avatar
It's not a tune, it's just a flash, the dealer needs to turn on cruise option in your ECU. Won't have any effect on your tune.
2stangs8689 is offline
post #3 of 6 (permalink) Old 04-22-2014, 09:48 AM
When I added cruise control to my bike the cpu was already flashed. I called the dealer and cancelled my appointment.
post #4 of 6 (permalink) Old 04-22-2014, 09:53 AM
stripclub's Avatar
I added cruise to my bike, after I had everything installed, I went back to the dealer I purchased the bike new from, they did turn the cruise function on in the ECM, took about 10 minutes, longer to remove the bag, side cover, and hook up the computer. Believe it or not all done at no charge by Warren Harley Davidson. I did throw the tech a 20 for some beers after work.
stripclub is offline
post #5 of 6 (permalink) Old 04-22-2014, 11:35 AM
Lol, I forgot to mention that, you MAY not need a dealer visit, some work after the install.
post #6 of 6 (permalink) Old 04-22-2014, 01:07 PM
CNMTurner's Avatar
I installed cruise myself and did not need the flash from the dealer.. It was already turn on in the ECM and waiting.. So.. after installing it.. Hit the power button on the console and if you get a lil red dial on your Speedo.. You're golden.. Test it out.. when you engage the red dial will turn green.. If not.. Then you'll need a flash at the dealer..
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
Cruise Control Failure After Handlebar Swap Stoic Joker Controls & Handlebars 0 01-13-2018 04:13 PM
Cruise control, learned something new madmat Controls & Handlebars 77 12-30-2016 10:02 PM
Cruise control shutting down rocun Troubleshooting for Road Glides 22 10-29-2014 06:48 PM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
Cruise Control won't maintain speed BigTirez Troubleshooting for Road Glides 4 10-17-2011 09:04 PM
