2012 Road glide vapor lock help! - Road Glide Forums
post #1 of 15 (permalink) Old 05-06-2014, 03:31 PM Thread Starter
nhga47's Avatar
Angry 2012 Road glide vapor lock help!
All,
I was wondering if anyone could help me out here. I just moved from NM which is about 6 to 8K feet elevation to oregon which is pretty close to sea level. I am having issues with power, stalling, and all kinds of shit here. I don't think it likes oregon! I was wondering if anyone has had experience with the power commander and if it is easy to load new maps on your own, or if its just better to take it to the dealer. Either way this has got to get fixed. It had all kinds of power in NM. I can't get out of my own way here! Thanks in advance.
Nolan Proud road glide owner!
From my COLD DEAD HANDS!
nhga47 is offline
post #2 of 15 (permalink) Old 05-06-2014, 04:19 PM
faststan's Avatar
Change in elevation will give you a lean condition. Not knowing what you have on your RG pertaining to exhaust/AC it is hard to suggest one thing that may help. If everything is stock I would take it to the dealer and get a new download. If you have pipes/AC I would suggest you get the PV. Maps are available from Fuel Moto if you buy PV from him. More information is required.
Do you work for Intel?
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 15 (permalink) Old 05-06-2014, 04:27 PM
Bull_Duck's Avatar
I have had my normally aspirated ( carborated ) 2000 Duce at sea level in Florida, and the highest mountain passes in Colorado. For example, Vail Pass is 10500 ft. No problem. Same with 2008 Road Glide. Perhaps I was not getting optimal combustion, but what I get/got is good enough.
Bull_Duck is offline
post #4 of 15 (permalink) Old 05-06-2014, 04:52 PM Thread Starter
nhga47's Avatar
to faststan
Yes sir. I do work for Intel. I am here in Oregon from NM. My bike is pretty stock except for the exhaust which are Tailgunners. its a hopped up 103 with the stage 4. Nothing aftermarket though but the pipes. I do have the module for downloads which came with the bike. It was running great there in NM. IT is not happy right now. Thanks for all the help!
Nolan
Beaverton Oregon
[email protected]
nhga47 is offline
post #5 of 15 (permalink) Old 05-06-2014, 06:19 PM
crossbonesglide's Avatar
Your bike has a sensor, can't remember it's name, I know there is one called a Map sensor. I know modern bikes adjusts for elevations. Maybe it's not working properly, is the bike giving any error codes?
crossbonesglide is offline
post #6 of 15 (permalink) Old 05-06-2014, 06:22 PM Thread Starter
nhga47's Avatar
error codes
as far as I know its not. What would I need to do to find them on a 2012? does it have a maintenance light or something like that on the speedo/tac?
nhga47 is offline
post #7 of 15 (permalink) Old 05-06-2014, 06:38 PM
faststan's Avatar
Nolan
Beaverton Oregon
[email protected]
I used to work out of Gilbert office long time ago. Travelled to Rio Rancho, Austin, Oregon, Calif to train people on PC's. Main office was in Deer Valley for my department in Az. Prolly not a lot of other businesses with offices in Rio Rancho and Oregon. I also worked for Grantree Furniture in Portland. I don't know if they are still around.
Since it is a '12 it should still be in warranty. Let the dealer worry about it. A stage 4 is not pretty much stock. You may need to get a dyno tune since you have the module for downloads (SEPST/SERT)?
faststan is offline
post #8 of 15 (permalink) Old 05-07-2014, 05:50 AM
I believe in the speedo a light will flash several times, not the abs light if installed. How many times it flashes is an error code and some where on the boards here is a key to the codes. I wonder if you could unplug the power commander? But I think a Power Commander bypasses your O2 sensors. You might have to put those back on if they were disabled. Getting more complicated now.
post #9 of 15 (permalink) Old 05-07-2014, 09:18 AM
DED HD's Avatar
If you are running a power commander, your bike will not adjust to compensate for the difference in elevation. The SE Super tuner will adjust, but the Power Commander will not.
You need to re-tune, or download a map for your build. Downloading maps is easy.
'10 Red Custom:
DED HD is offline
post #10 of 15 (permalink) Old 05-07-2014, 10:01 AM
All the info you need to access your DTCs are in the troubleshooting section of this forum and you can use the 2010 and later DTC code list to help diagnose your problems.
The bikes ECM with stock O2 sensors should adjust for all elevation changes.
13 and under Tourpak lock with 15+ key help Steelerdude1 *General Road Glide Discussions/Pictures 6 01-11-2016 09:49 PM
Tour Pack Lock W/Flat Key Lock. Bill-99RG *General Road Glide Discussions/Pictures 3 01-15-2015 01:16 AM
Need help with Fuel vapor escaping on Left side of Heads CNMTurner Engine Related 18 04-18-2014 02:54 PM
trade 2011 road glide custom for 2012-13 CVO road glide durtybiker Bikes for Sale 0 09-24-2013 08:25 PM
