stage 2 advice - Road Glide Forums
post #1 of 4 (permalink) Old 05-07-2014, 06:34 PM Thread Starter
stage 2 advice
OK here goes. I have a 13 ultra that has tru duals, hi flow air cleaner, and a automatic tuner. When I had the local dealer install cams they put a download in. My question is this, Should I put back on the tuner or just go with the download. And if I do put on the tuner will this take my download off the ECM if I remove the tuner. Sure hope that made a lick of sense.
bruce hurt is offline
post #2 of 4 (permalink) Old 05-07-2014, 06:56 PM
What kind of tuner are you using?
post #3 of 4 (permalink) Old 05-07-2014, 07:14 PM Thread Starter
RC components
post #4 of 4 (permalink) Old 05-08-2014, 10:20 AM
If the bike runs good and you are happy then just stick with the download. If you are having tuning issues then use the tuner. In most cases a tuner will help the bike run better and cooler so it would be good to have the bike dyno tuned using a tuner.
Need stage 1 advice railer60 Intake and Exhaust 24 05-31-2016 08:13 AM
Upgraing Boom Stage II advice needed. chinashop bull Audio 9 01-24-2016 09:54 PM
Stage 1 and Stage 1 Howardsternspenis Intake and Exhaust 3 01-01-2012 11:38 PM
Stage I and Stage II air filters RoadGlide0611 Intake and Exhaust 10 10-17-2011 09:01 AM
Stage 1 to Stage 2 progression Indy Road Dog Engine Related 2 10-21-2010 06:18 AM
