Thundermax firmware upgrade - Road Glide Forums
post #1 of 8 (permalink) Old 05-13-2014, 07:26 PM Thread Starter
TRUBlue's Avatar
For all you other TMax users - there's a new firmware download with "Wave tune" technology available now.
Go to: http://www.thunder-max.com/Support/T...xSoftware.aspx
and download the file. Supposed to tune 3x faster. They show an example: http://www.thunder-max.com/NewsAndEvents/WaveTune.aspx
I've updated my firmware and will ride tomorrow after work. Anxious to see how well it works.
'12 FLTRU Big Blue Pearl
TRUBlue is offline
post #2 of 8 (permalink) Old 05-25-2014, 09:34 PM
I just upgraded the Tmax pc software & Tmax ECM firmware. In the process I adjusted the high rpm timing due to pinging. Took my FLTRU out for a two hour spin and it ran considerably better. My starting issues seem to be gone as well as the pinging. I'm very happy with the updates and so far so good!
V&H X-Pipes, V&H Monster Ovals, Arlen Ness Air Cleaner, Stock Cams
2017 Road Glide Ultra FLTRU
spotfire is offline
post #3 of 8 (permalink) Old 05-25-2014, 09:49 PM Thread Starter
TRUBlue's Avatar
Yep, updating, mine runs better on the updated map, mpg went up, starts easier, especially when hot.
TRUBlue is offline
post #4 of 8 (permalink) Old 05-25-2014, 10:23 PM
PFWiz's Avatar
Cool, gotta get mine updated ASAP!
Thanks for the heads up!
PFWiz is offline
post #5 of 8 (permalink) Old 05-26-2014, 06:04 AM Thread Starter
TRUBlue's Avatar
It's not the most straight forward procedure. First go to http://www.thunder-max.com/Support/T...xSoftware.aspx then click the yellow disc and download the file to your hard drive. Open the file and click the "setup" file. It will then do its thing. You don't need to be linked to the bike to download but you do to actually do the update and if all else fails, email them, they reply fairly quickly.
TRUBlue is offline
post #6 of 8 (permalink) Old 05-08-2015, 04:57 PM
SMOKENJOE's Avatar
Advanced User Authorization
ANYONE USING THE Advanced User Authorization TO BUILD YOUR OWN MAP?
http://www.thunder-max.com/TechDocs/AdvanceUserAuth.pdf
By Contacting ThunderMax Tech supportat [email protected], you can request an
Advanced User AuthorizationCode
which allows the user access to more features and tools within
the Software.In order for the Tech SupportAgent
to be able to provide this Access Code, you must provide theagent with the
Serial Numberfrom the Software
SMOKENJOE is offline
post #7 of 8 (permalink) Old 05-08-2015, 05:34 PM
SMOKENJOE's Avatar
Originally Posted by trublue View Post
for all you other tmax users - there's a new firmware download with "wave tune" technology available now.
Go to: http://www.thunder-max.com/support/t...xsoftware.aspx
and download the file. Supposed to tune 3x faster. They show an example: http://www.thunder-max.com/newsandevents/wavetune.aspx
i've updated my firmware and will ride tomorrow after work. Anxious to see how well it works.
look at the finish the wave tune smoothed out the performance but the stock t max even after it was finished was still rough makes you wonder if the t max without the upgrade was as good as they said it was
post #8 of 8 (permalink) Old 05-08-2015, 10:58 PM
WarBootie is offline
New WHIM Firmware Update Failure WTFranz Audio 11 05-29-2019 06:22 AM
Sena firmware update to V1.7.7 smitty901 Audio 2 05-21-2018 08:50 AM
New Firmware for Boom Infotainment sblair *General Road Glide Discussions/Pictures 8 01-22-2015 04:06 PM
Thundermax impression Rowdy ECM/Fuel Management systems 9 11-23-2010 09:27 PM
Zipper Thundermax Ranger58 ECM/Fuel Management systems 12 11-19-2010 10:26 AM
