Backfiring from Airbox - Road Glide Forums
post #1 of 6 (permalink) Old 05-16-2014, 10:42 AM Thread Starter
ccallahan's Avatar
Hey Folks,
So here's my tale. I replaced the Push rods and lifters in my 2011 Road Glide CVO because I suspected I had a lazy lifter. It worked. Nice an Quiet now.
At the same time I put on a set of V&H Power Duals with Monster Squares and a RSD Turbine Air Cleaner Kit. Fuel Motor sent me a new Flash for the system, but it doesn't seem to run right. Now the Diagnostics Log is giving a bunch of errors. Not sure if this is Mapping related or Electrical.....here's the Log
Beginning operation: ReadDTCs
ECM: 1 trips since last DTC.
TSSM:B1154 HIST
Clutch Switch Short to Ground
ECM:P0120 HIST
Throttle Position sensor 1 range
error
ECM:P0123 HIST
TP Sensor High EFI
80:U1307 HIST
ECM:P0131 HIST
Front O2 sensor low (lean)
ECM:P0132 HIST
Front O2 sensor high (rich)
ECM:P0151 HIST
Rear O2 sensor low (lean)
ECM:P0152 HIST
Rear O2 sensor high (rich)
ECM:P0220 HIST
Throttle position sensor 2 range
error
ECM:P0222 HIST
Throttle position sensor 2 low/open
ECM:P1003 HIST
System relay Contacts Open EFI
ECM:P1510 HIST
Throttle actuator control limited
performance
ECM:P1511 HIST
Throttle actuator limited power
mananagement mode
Operation Returned 0:
End of operation.
My Wrench is pretty busy so looking for a bit of help to see if I can correct this myself or not.
I Choose to live by choice, not chance; to make changes, not excuses;to be motivated, not manipulated;to be useful, not used;to excel, not compete;I choose self esteem, not self pity;I choose to listen to my inner voice, and not the random opionions of others.
ccallahan is offline
post #2 of 6 (permalink) Old 05-16-2014, 10:58 AM
With that many codes I'd clear them and try it to see if all of them come back. If your push rods are the adjustable type I'd make sure the are adjusted properly. Double check the tuner is working as it should be. I'd also call to talk to someone to make sure you got the correct map for your set up
rlaf75 is online now
post #3 of 6 (permalink) Old 05-16-2014, 11:01 AM Thread Starter
ccallahan's Avatar
Unhappy
Reset the push rods last night just to make sure they were adjusted properly.
Sent a help email to Fuel Moto to see about the Flash they sent me for the power Vision. This is the day after I cleared the codes.....
post #4 of 6 (permalink) Old 05-16-2014, 11:14 AM
How is the bike running after you cleared the DTCs ? The backfiring out of the intake is a tune problem and is related to the new exhaust and intake, new pushrods and lifters will not cause your problem.
After you cleared the DTCs ride the bike and see if any DTCS return.
post #5 of 6 (permalink) Old 05-16-2014, 11:50 AM
mocotom's Avatar
If the backfiring occurs when you rapidly open the throttle from idle it is an indication of a/f mixture going lean. I would call Fuel Moto for help rather than e-mail them. I'm sure Jamie has said on this site that they can at times address the problem better by phone.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #6 of 6 (permalink) Old 05-16-2014, 01:11 PM Thread Starter
ccallahan's Avatar
Talked to Brian at Fuel Moto.
Looks like I may be the cause of the issue.
Black O2 Sensor has to go to the Back!!! Not the front. Crap!!
Thanks Brian.
Exhaust Backfiring? SacRider Intake and Exhaust 5 04-14-2015 11:48 AM
Backfiring Question ODA CDR (RET) *General Road Glide Discussions/Pictures 10 06-05-2012 06:34 PM
