New 2014 runs like crap with PCV - Road Glide Forums
post #1 of 11 (permalink) Old 05-31-2014, 07:19 PM Thread Starter
Brianu1's Avatar
My buddy bought a new 2014 Street glide special. Put the SE air filter in, Rinehart slip-ons, and a PCV. He has disabled the EITMS, and the bike at idle runs horrible. It has also killed a few times. I haven't checked what map the dealer put in it yet, but will do that. PC does have a map for his setup. Any ideas? Thanks and sorry, I know it's not a RG (too bad for him)!
FLTRX, Black Edge Cut Blade wheels & rotors, RSD Seat, TW-777, V&H Power Duals w/ CFR's, Daymakers, SE A/C, PV tuner, Soundz Customz LV-4 audio, Klockwerks Flare 12" smoke, CD LED's, Progressive shocks, & lots of others...
Brianu1 is offline
post #2 of 11 (permalink) Old 06-02-2014, 12:12 AM
On pcv you must unplug the O2 sensors.
dllinniy is offline
post #3 of 11 (permalink) Old 06-02-2014, 12:30 AM
tmd
Never understood why anyone would shut off EITMS not that it has anything to do with the sounds of your problem. Connect your laptop to it and see what map is downloaded into it. You can also go to their website and choose from hundreds of maps to try out .
tmd is offline
post #4 of 11 (permalink) Old 06-02-2014, 06:08 AM
kouack's Avatar
The 2014 have a HO engines aka se255 cams in them, i would look for a map for a 103 with cam AC and slipon to start with if was mine. Look at map 15-011-138 probably close enough. + 1 for O2 sensors. Also you can send an email to PC they Will help you to chose a map.
kouack is offline
post #5 of 11 (permalink) Old 06-02-2014, 06:35 AM
I am sorry to drift a little on this thread, but are you saying the 2014s come from the factory with a Screaming Eagle 255 cam?
grambo is offline
post #6 of 11 (permalink) Old 06-02-2014, 06:51 AM
kouack's Avatar
From what have read the have similar cam spec, an easy map to try would the one with a se255. said close your best is to hit a dyno to get the best tune.
kouack is offline
post #7 of 11 (permalink) Old 06-02-2014, 09:46 AM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
If his 14 bike is having an idle issue there is an updated O2 eliminator that can be supplied by Dynojet for bikes that are affected. I would first make sure it is not a mapping issue, be sure you are using the correct map for the appropriate air cooled or twin cooled motor.
[/color]
The 2014 maps were developed with specific combinations on 2014 bikes which includes the new H.O cams. Do not use a map for the SE255 cams unless the motor has them, and absolutely do not use 2013-earlier map as the ECM and everything map wise is completely different.
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #8 of 11 (permalink) Old 06-02-2014, 10:33 PM Thread Starter
Brianu1's Avatar
Ok, so one response was to remove the O2 sensors? Is that correct? I don't have them in my 13 with the PC, runs good. Anyone else believe they should be removed? I've been told by some it doesn't matter?
Brianu1 is offline
post #9 of 11 (permalink) Old 06-03-2014, 06:40 AM
kouack's Avatar
Good to know thank you, i was sure the map would be in the ball park to try to figure out what going on, i was totaly wrong.
kouack is offline
post #10 of 11 (permalink) Old 06-03-2014, 07:30 AM
PAVEMENTPILOT's Avatar
On my '13, after installing PCV with correct map, I unplugged O2 sensors but left them mounted in header pipe. Had bike dyno'd and it runs mint. Call Jamie @ Fuel Moto if you have any questions with mapping. Those guys are very helpful.
PAVEMENTPILOT is offline
2014 FLHTK Twin Cooled 103 Stock Dyno runs fuelmoto Dyno Results 8 04-21-2014 11:51 AM
Runs like poo too.... willbo22 Engine Related 12 09-24-2013 12:24 AM
Runs like poo Lowmaks Troubleshooting for Road Glides 32 07-10-2013 11:55 AM
08 Fltr Running like crap again.....help! skipperfltr Troubleshooting for Road Glides 10 10-02-2011 04:05 PM
Took my bike out west and now runs like crap Ozoneman *General Road Glide Discussions/Pictures 25 09-12-2011 05:34 PM
