RE Start 2-3 Times - Road Glide Forums
post #1 of 24 (permalink) Old 06-19-2014, 08:06 AM Thread Starter
rookie racer's Avatar
RE Start 2-3 Times
I am having a hell of a time getting my bike to start and stay running the first time. It always dies {cold} on the first start. Have to hit the started again.
I have tried to add the IAC Steps, Warmup Enrichment and other settings related to cold starting. Starts good when warm.
It has done this since Day 1 when i bought the bike, Even when the SERT was in it. I now have TTS Master Tune. No {02 Sensors}
Any help would be GREAT !
Other than starting, The bike runs Great. 45 mpg.
Scott
2015 Road Glide Special
Amber Whiskey
rookie racer is offline
post #2 of 24 (permalink) Old 06-25-2014, 05:44 PM Thread Starter
After reading other forums and talking to bike techs. If I take gas cap off turn on fuel pump you can hear the pump whine then shut off. There is a hissing sound. I guess that means there is a leak in the fuel line.
Ordered a new check valve assembled and fuel filter kit. Gonna tear into it soon.as I get the new parts.
Pretty sure that's what's causing the issue
Scott
Amber Whiskey
post #3 of 24 (permalink) Old 06-25-2014, 06:44 PM
Mine did that for a while. I changed spark plugs and it fires up first time and stays running, every time.
post #4 of 24 (permalink) Old 06-25-2014, 07:07 PM
My friend had a similar issue with his stock 07 Ultra. I could hear a similar sound & it was a small leak in one of the hoses inside the tank.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #5 of 24 (permalink) Old 06-28-2014, 08:20 PM Thread Starter
UPDATE: Removed the canopy, Installed new fuel filter kit, and Check Valve assembly. Found a hole in fuel line filter to fuel pump. Looks like it rubbed against the arm on the pump.
Still had had to start twice DAMMIT . Threw a code, Cleared it thanks to IronMark's sticky .
I will know more in the morning. On cold start.
Thanks for u all' help ! I love this forum!
Scott
Amber Whiskey
post #6 of 24 (permalink) Old 06-29-2014, 09:01 AM Thread Starter
Cold start this morning. No change, still have to hit starter twice. RPM's. go up to 2000 then jump back down to 1000, then it sneezes thru the A/C, then dies . Just like before . Going to check CKP Sensor now. I gotta get this right.
Scott
Amber Whiskey
post #7 of 24 (permalink) Old 06-29-2014, 09:42 AM Thread Starter
How do I test crank position sensor ? PLEASE !
Scott
Amber Whiskey
post #8 of 24 (permalink) Old 06-29-2014, 09:56 AM
Did you check the Idle Air Control (IAC) ?? Did You check the MAP sensor??
Chances are it isn't the crank positioning sensor, if that was bad your bike probably wouldn't run good because your timing would be way off.
I am sure there are ways to check sensors but for us backyard mechanics just swapping the sensor out is the easiest way but it can get costly because we are just guessing if there is no DTCs
post #9 of 24 (permalink) Old 06-29-2014, 12:49 PM Thread Starter
No I did not check any other sensors. Just reading old posts and guessing. I did have a code P1353 . Cleared it.
So do I just go buy a new IAC and MAP Sensor ? I don't care what it cost, just want to get my bike going.
Scott
Amber Whiskey
post #10 of 24 (permalink) Old 06-29-2014, 02:36 PM Thread Starter
IronMark
Don't know how long that code P1353 has been there, I just found out how to get codes yesterday, do you think that has anything to do with my issue ?
Scott
Amber Whiskey
Crank no start, crank start Sam07 Troubleshooting for Road Glides 10 05-15-2018 08:03 AM
WILD TIMES - daytona FALL '10 h-donut *General Road Glide Discussions/Pictures 15 04-24-2012 08:15 PM
1/4 Mile Drag Times gbourdon *General Road Glide Discussions/Pictures 12 08-05-2011 10:16 PM
Sign of the times? TracyB General Off-Topic Discussions 15 03-09-2011 07:41 AM
Hot times in the Smokies dikdark Road Trip Discussions/Stories/Pictures 11 09-08-2010 02:24 PM
