PCV with autotune and rear cylinder shutoff - Road Glide Forums
post #1 of 6 (permalink) Old 06-25-2014, 10:48 AM Thread Starter
toogood8p's Avatar
Does anyone known if the PCV with autotune recognizes when the rear cylinder shutoff happens?
Twice when hot, bike idle stumbled and either stalled or almost stalled. I was wondering if the PCV understands the shutoff or if I missed an option in setup
Bear, Prez, Kindred MC
13 FLTRX - Candy Orange - Daymakers, Custom Dynamics - LED turn signals, Kuryakyn Scythe mirrors, Iron Aces bracket, X-grip, floor board extensions, custom sundowner seat, black KW 8", PCV, auto tune, Stage 1 AC, Drago H-pipe, 4" Dragula mufflers.
toogood8p is offline
post #2 of 6 (permalink) Old 06-25-2014, 07:03 PM Thread Starter
toogood8p's Avatar
Bump
post #3 of 6 (permalink) Old 06-25-2014, 09:14 PM
That's a good question...
I always make sure that the rear cyl shut off is deactivated.
HeatWave is offline
post #4 of 6 (permalink) Old 06-25-2014, 09:41 PM Thread Starter
toogood8p's Avatar
I was thinking of doing that and looking at the "JIMS Force Flow" to help with the cooling
post #5 of 6 (permalink) Old 06-25-2014, 10:15 PM
mitchdm's Avatar
I shutoff my rear cylinder shutoff stock or modified. Which would normally occur at very high heat... What I and many others have found is to not utilize the autotune at idle... I have all of my fuel adjustments for both cylinders set to 0 at idle also. I checked the AFR's at Idle with no fuel and or settings within the target afr's and it is idling at 13... I am good with this number, the AT at idle can lead to the bike doing some strange things....
mitchdm is offline
post #6 of 6 (permalink) Old 06-26-2014, 09:50 AM
I am not familiar with the PCV but if it piggy backs to the stock ECM then I wouldn't think it would matter. The Stock ECM will monitor cylinder head temps and activate/deactivate the EITMS (as long as you have it turned on)and the PCV should not be able to affect that function.
CVO Hydraulic Clutch Cylinder and Master Cylinder. tech643 Parts for Sale 3 04-29-2014 12:07 PM
PCV and Autotune Module F/S x52gnr Classifieds Archive (3 months old+) 6 04-23-2012 06:03 PM
PCV Autotune timing 615McCord ECM/Fuel Management systems 2 02-14-2012 09:06 AM
PCV Autotune 615McCord ECM/Fuel Management systems 3 11-26-2011 08:42 PM
PCV AutoTune full exhaust and stage 1 filter 615McCord Road Glide Specific Discussions 1 11-13-2011 07:20 PM
