Clean Inside of Tank - Road Glide Forums
post #1 of 7 (permalink) Old 06-25-2014, 02:10 PM Thread Starter
Q-Hog's Avatar
I'm preparing to swap out the fueling system from one tank to another. Any recommendations on what to clean the new tank out with since it's been recently sealed and pressurized? Thx
Q-Hog is offline
post #2 of 7 (permalink) Old 06-25-2014, 02:25 PM
Shark of the Month August 13
SIC_26's Avatar
Gas! Lol I just washed mine out with gas to get any dust out and called it good
Sent from Motorcycle.com App
SIC_26 is offline
post #3 of 7 (permalink) Old 06-25-2014, 02:29 PM Thread Starter
Q-Hog's Avatar
Sic to the rescue....That was my first choice.. But wasn't sure. This learn-as-you-go bike building in mentally tiring.. LoL
Q-Hog is offline
post #4 of 7 (permalink) Old 06-25-2014, 02:58 PM
harley75's Avatar
kerosence
But Im not sure why I used it, maybe because it was an old tank that was peeling on the inside
75 Superglide
04 Texas Chopper
10 RGC
harley75 is offline
post #5 of 7 (permalink) Old 06-25-2014, 03:02 PM
SIC_26's Avatar
LOL I just figured gas was what was going to be in there and I wouldn't have to worry about trying to get 100% of "some cleaner" out never had an issue on any of the bikes with this method
SIC_26 is offline
post #6 of 7 (permalink) Old 06-25-2014, 05:05 PM
calgaryglide's Avatar
Gasoline to rinse out the tank.
I find it easier to undo that cam ring while the tank is bolted to the frame, the rest can be done with the tank off the bike.
The guts are not difficult to remove but do require some patience. After you remove cam ring the next difficult thing to remove is the black grounding wire, feel for the tag or clip make sure it is depressed then the wire will slide out.
Remove the two hoses from the filter housing, one is the pickup hose for the pump and the other is the delivery hose to exit the tank. The filler/filter assembly should now come out of the tank. Lift the assembly and turn it clockwise and rotate it 90° from the horizontal so the gas cap would be facing the rear of the bike. Do this in one motion.
The remainder of the apparatus is clipped into slots in the tank. This includes sending level float and the pickup hose as well as the pump assembly. Undo the pickup hose first, then unclip the fuel pump and the float. You will have to rotate them as well to remove them. I don't recall which way I rotated them for removal.
When you remove the fitting from the bottom of the old tank be sure to reach into the tank and turn the hose that is connected to the fitting with your other hand. If you don't the hose can kink and split and that results in rough running and less than optimal acceleration
Put in a new fuel filter and o ring on the filter housing before you install in in the new tank. Put it all back together in reverse order. Make sure the cam ring is install with the word "TOP" facing up and at the front of the tank.
Calgaryglide
2019 FLTRU, Tyggr
calgaryglide is online now
post #7 of 7 (permalink) Old 06-25-2014, 05:18 PM Thread Starter
Q-Hog's Avatar
Thx for the detailed instructions. I will attempt it tonight. I already removed the cam ring with a Lang tool. I'll post my results... we'll see how this goes.. LoL
Q-Hog is offline
Must Be All That Clean Livin' Ran8175 *General Road Glide Discussions/Pictures 8 08-07-2011 08:39 AM
Clean 02 Road King for sale unyalli Classifieds Archive (3 months old+) 1 05-26-2011 03:53 PM
So clean i had to take a picture Defy *General Road Glide Discussions/Pictures 11 05-16-2011 08:05 PM
Didn't someone with an 09 RG find a HD tank badge that covered the tank decal? scott *General Road Glide Discussions/Pictures 5 02-25-2011 01:09 PM
Quick Wheel Clean Up... FLTRI *General Road Glide Discussions/Pictures 8 08-31-2010 07:59 PM
