ECM replacement and Power Vision - Road Glide Forums
post #1 of 5 (permalink) Old 06-28-2014, 08:11 AM Thread Starter
Ranger75's Avatar
I started a thread a few weeks ago in the troubleshooting section ref some odd electrical issues with my 12 RGC and some of the DTC's it was throwing. After trying to track them down I'm leaning more & more towards the ECM itself. Sadly I'm going to have to bring it up to Great South HD today and have them knock out the 20k service, change the front tire, and track down & fix my electrical gremlins. (Hate this because I normally service my own stuff) although I've always had good experiences with G.S. HD.
If the root cause of the problems turns out to be the ECM & it needs replacing:
1. Will my PV work with the new ECM since it's married to the old? I'm assuming yes as the new ECM would need to be programmed by the dealer and I'm guessing that would make it a mirror image of the old. I hope so - $500 for a PV...
2. Will I need to leave my PV with the service department?
3. If #2 is no, would service most likely flash a new ECM back to the original map, meaning I would need to bring my PV with when picking up the bike in order to reflash my tune?
4. Do y'all reckon the dealer will balk at doing ESP covered work being that I'm running a non-OEM Stage 1 & after market tuner?
Thanks.
Be polite, be professional, but have a plan to kill everyone you meet.
Ranger75 is offline
post #2 of 5 (permalink) Old 06-28-2014, 08:26 AM
You can get a transfer from dynojet for the PV. Go to their website it will tell you how. I did this when I moved my PV from my streetglide to my roadglide. If you contact them they may send it to you at no cost since it is the same bike. Your map should still be on it so then just flash it on the new ecm.
2013 Ultra
Pics here:
rg_dave is offline
post #3 of 5 (permalink) Old 06-28-2014, 08:48 AM Thread Starter
Ranger75's Avatar
Thanks Dave, good to know. Do you think I should put my stock air cleaner back on and flash the original tune prior to bringing it to the dealer for Extended Service Plan work or do you reckon it would be OK to leave it as is? Hate to do that but I'd also hate to have to pay for something that would normally be covered under the plan...
Ranger75 is offline
post #4 of 5 (permalink) Old 06-28-2014, 03:49 PM
skratch's Avatar
play it safe. put your original ac and map back in it. it's not like you're changing out a set of cams. you can reflash it back after you get your bike back. dynojet should be able to help you in transferring the license to the new ecm.
skratch is offline
post #5 of 5 (permalink) Old 06-28-2014, 04:18 PM Thread Starter
Ranger75's Avatar
Skratch, thanks & that's what I did. Dropped it off earlier today. Pretty sure Great South would have hooked me up, they always have - but with the 20k, tire change, etc. I really didn't want to get chumped & have to pay for the diag & repairs as well. Your post helps me think I didn't waste my time.
Ranger75 is offline
$799 Power Package Street Outlaw mufflers, Power Vision, FM Stage 1 AC fuelmoto Fuel Moto 7 06-16-2018 02:37 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
ThunderMax ECM with V&H Power Duals Jeffman ECM/Fuel Management systems 7 04-02-2014 01:08 PM
power vision does see ecm rad ECM/Fuel Management systems 7 11-07-2011 12:01 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
