Engine Stalling - Road Glide Forums
post #1 of 20 (permalink) Old 07-12-2010, 09:08 PM Thread Starter
connector's Avatar
Question Engine Stalling
Started last week and changed the air filter ,was in need but that didn't help. After the bikes gets a little hot and i come to a stop the idle starts to fluxuate + - a couple hundred rpms. Now when i give a little gas it stutters a little and completely dies. Somtimes it will bog down for a secound and regain proper rpms. I don't have the cylinder deactivication enabled so its not that. Its in the shop right now ,just wondering if anyone else has experianced this before
09 FLTR 103 Stage III
connector is offline
post #2 of 20 (permalink) Old 07-12-2010, 10:06 PM
T-BO 399's Avatar
I noticed my 09 doing the same kind of thing on my way home from work today. It didn't stall but when I would come to a red light it sounded like it could. It was enough to cause me to rev it up a bit to take off. It almost seemed like it was loading up a bit so I tried riding it a little harder. The oil temp gauge was at 220.
2009 FLTR, BLACK PEARL
T-BO 399 is offline
post #3 of 20 (permalink) Old 07-12-2010, 10:20 PM Thread Starter
connector's Avatar
Sounds familar , started very sutble and got worse pretty quick. I tried reving it and that worked for awhile. But after a week then just bogged the engine when i reved it and stalled it . All in the intersection at this point
post #4 of 20 (permalink) Old 07-12-2010, 11:02 PM
xusnatc's Avatar
Sounds like the crankshaft position sensor.
xusnatc is offline
post #5 of 20 (permalink) Old 07-13-2010, 10:55 AM
watchdog's Avatar
My 07 doing the same thing. When i come to a stop the rpm drops to 800-900 and stalls. It starts right back up, but i find myself trying to keep it around 1000 rpm when i come to a stop.
watchdog is offline
post #6 of 20 (permalink) Old 07-13-2010, 12:25 PM
Rowdy's Avatar
Hmmmm
These symtoms sound familiar but different at the same time. Mine is stalling once in a while when I start it first thing in the morning. It did it at the HD shop on the first service and then didn't do it again till I was out on the road. Now it's done it about 4 times. It hadn't thrown any codes when it happened at the shop, and it does start back up on the first try at this point, but still makes me wonder what's up. It's going in for the 5K soon, as in the next week or so, I am going to have them check it out again.
Rowdy is offline
post #7 of 20 (permalink) Old 07-13-2010, 02:41 PM
watchdog's Avatar
Mine only does it once its warmed up. I guess the computer probably steps up the idle until it warms up.
watchdog is offline
post #8 of 20 (permalink) Old 07-13-2010, 10:20 PM
makindue
Guest
Posts: n/a
Hi watchdog, I agree with you. I really love mine because in once it warmed up, it will be last longer.
post #9 of 20 (permalink) Old 07-14-2010, 10:25 PM
T-BO 399's Avatar
I have tried riding my 09 a little higher in the rpm range closer to 3000 than 2000 and I noticed a little improvement when I wait for a light in gear holding the clutch lever in. It made a big difference when I was in neutral. I have noticed there is more slack in the clutch cable when it's cold. I wonder if the heat can create extra drag on the clutch like its not all the way pulled in.
T-BO 399 is offline
post #10 of 20 (permalink) Old 07-14-2010, 10:41 PM Thread Starter
connector's Avatar
Shop is going to change my throttle postion sensor. No codes but they have had a few 09 in and this corrected the problem. Im hoping it works as it is prime riding season for us up here and its been 3 weeks and i've got maybe a hour in
Engine bucking, stalling, high idle, sputtering Taccone *General Road Glide Discussions/Pictures 31 02-23-2018 09:34 PM
Engine stalling jj8823 Engine Related 9 06-18-2014 05:41 PM
Need Advise- Stalling and Hesitating BDMastiff Troubleshooting for Road Glides 10 09-19-2010 07:20 PM
2000 Screaming Eagle Stalling Skycop26 Troubleshooting for Road Glides 0 09-13-2010 05:46 AM
07 stalling problem watchdog Troubleshooting for Road Glides 3 07-07-2010 10:37 AM
