PCV Map HELP!!!!!!!! - Road Glide Forums
post #1 of 1 (permalink) Old 07-21-2014, 02:50 PM Thread Starter
hamer007's Avatar
any one have a good running map that works with this set up, se high flow aircleaner(football style) V&H Power dual , V&H High outputs, se 255 cams, I have a 2012 RGU, got one from Fuel Moto , not sure if it close enough, any one that can share their working map with me for comparison would be highly appreciated, you can send to [email protected] or attach here if its possible, thanks
2012 RGU Black,8 inch Klockwerks windshield,
Power Commander V,Vance&Hines Power Duals w/ high Outputs, Screaming Eagle High flow A/C,
PYO 10 inch Monkee Bars and alot of Wille G Skulls
hamer007 is offline
PCV map help SwarleyManson62 ECM/Fuel Management systems 0 05-20-2016 10:47 PM
PCV Map help? moleng1 ECM/Fuel Management systems 7 10-28-2015 07:20 PM
Help w/Map for PCV sftosendai ECM/Fuel Management systems 6 06-16-2011 09:31 AM
FatCat Boss 2into1 pcv map bigtwin Intake and Exhaust 0 10-24-2010 08:35 AM
Need Pcv map for 2010 FLTRX Garcou ECM/Fuel Management systems 4 10-20-2010 05:41 AM
