Help needed with PC3 - Road Glide Forums
post #1 of 2 (permalink) Old 08-02-2014, 07:40 AM Thread Starter
Question Help needed with PC3
Hi all,
Not posted on here for ages.
I have a 2000 Road Glide with the Mangeti Marelli fuel injection.
I fitted a K&N filter and a set of the CFR knockoffs the other week and found the bike was running very lean(as in you can not touch the end off the right hand muffler after 2 miles without burning yourself!) so to help with fueling I purchased a Power Commander 3 on the dreaded Fleabay.
Fitted the PC3 as per the install guide but all that happens when i try to start the bike is the fuel pump primes and the red engine light comes on goes off and then on again and the bike will not start at all. It just turns over.
I sent the unit to Dynojet UK. They checked it over and say its fine.
Anyone had similar issues.
Cheers,
Dave
davey1%er is offline
post #2 of 2 (permalink) Old 08-02-2014, 08:55 AM
Banned
Gotta have fuel and fire. Check for both? The connection on the M&M bikes isn't too grand. Make sure your connection into and out of your Pc3 is good. CFR's are not the typical muffler. They are almost like running straight pipes only they're bigger and flow more air. Well, I've never flowed a set but they are not good for bottom end torque, at least the previous version wasn't. I've heard they have changed them and now they do perform much better but I have not tried a set of the newer design yet. I recommend using a set of big city thunder baffles with those particular mufflers.
INDY #1 is offline
Tags
pc3
I want to tweak my map PC3, who's done it? JL Sargent ECM/Fuel Management systems 0 08-12-2012 02:44 PM
What to do about Ethanol /PC3 monte312 ECM/Fuel Management systems 11 04-13-2011 10:51 PM
What to do about Ethanol /PC3 monte312 ECM/Fuel Management systems 0 04-06-2011 10:58 AM
Flash2Pass - Headlight wiring help needed G *General Road Glide Discussions/Pictures 15 01-17-2011 11:31 PM
New to Harley's - Nightsitck Help Needed RoadGlide5150 Intake and Exhaust 13 06-13-2010 09:00 PM
