Marelli and Power Commander - Road Glide Forums
post #1 of 6 (permalink) Old 07-20-2010, 09:51 AM Thread Starter
I have a 2000 SERG with the Marelli system and want to gear drive a new 510 cam set along with A set of jackpot mufflers and a big sucker, all ive heard these can be a differnt animal. but not sure what to go with and if to do anything at all, the bike is stock with 20,000 miles, one local has sugested to to do a Delfi conversion another go with a P C and yet another the TTS Master tune. I just want a good running reliable bike wich is why i wanted to gear drive the cams in the first place, now am i opening a can of worms or what
fredflintstone is offline
post #2 of 6 (permalink) Old 07-20-2010, 10:15 AM
1BigGuy's Avatar
Your going to get different answers based on preference and experiance. Personally when I geared my Cams on a 2004 Electroglide standard, I used a Power commander and it worked well. Gearing is definitely a good way to increase torque. Once mine was done on the 88 engine with an open breather and true duals, I had no issue keeping up with 103's from a dead stop, it will help some on the top end, but the amount depends on the cam. It definitely makes the bike much more peppy.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #3 of 6 (permalink) Old 07-20-2010, 10:48 AM
dklanecky's Avatar
I'd ask Jamie at FuelMoto for his opinion. That guy has done an awful lot with Power Commanders and maps, for a lot of configurations. I believe he is the biggest PC dealer in the country (or something like that).
Call him, don't send an e-mail as they are so busy this time of year, you may never get a response to the e-mail.
http://www.fuelmotousa.com/
73 Sporty - Sold
07 Sporty - Sold
09 Vivid Black Road Glide (FLTR) with ABS, Security, Fuelmoto Satge One, Clearview, Harley Hammock Seat, Hogg Chopps Lowers, Bright Ass Tail Light, SERG Headlight Bezel, Detachable King Tour Pak, Painted Inner Fairing, Cruising Southeasten Wisconsin, Delivered 3/6/2009:clap:
09 Black Fat Bob (FXDF) in Vivid Black of course, Delivered 5/1/2009
dklanecky is offline
post #4 of 6 (permalink) Old 07-23-2010, 02:41 AM Thread Starter
looks like the PC is the way to go
post #5 of 6 (permalink) Old 07-23-2010, 08:43 PM
pte359's Avatar
I have a 99 with 95 in still running the MM injection, woods gear drives, PCIII, with big K&N breather, Rhinehart true duals and ported heads. 46k miles on the build, still doing 90.6 hp 98.8 ft # torque. Now the only draw back is the older PCIII will only do a single map, the newer PCIII USB will do seperate mapp for each cylinder. I love my setup and have NO problems with the MM and still getting around 50 mpg if I ride it rite.
Hope this helps.
If you decide to change the injection do your self a favor and look into the Horspower Inc replacement for the MM it is a plug and play unit no wiring harness changing
www.horsepowerinc.com
PROUD USAF Dad.....
pte359 is offline
post #6 of 6 (permalink) Old 07-23-2010, 11:41 PM Thread Starter
thanks for the info pte
Magnetti Marelli Issues StBlair New Members Welcome Area 11 08-21-2015 10:59 PM
LED's, power commander, power vision, and other items for touring models. Gasitman Parts for Sale 5 08-23-2014 12:29 AM
Power Commander and Tach Problems picksterRG ECM/Fuel Management systems 2 05-15-2011 11:22 PM
Magnetti Marelli TAZZMAN Intake and Exhaust 12 01-16-2011 07:51 PM
Power Commander V and Big Sucker Air Cleaner The Infamous Sharknose Equipment-RG 0 09-18-2009 10:07 AM
