116" 2005 Tuner info - Road Glide Forums
post #1 of 2 (permalink) Old 08-11-2014, 04:35 PM Thread Starter
I am looking for a tuner for my new engine build. It is a 116" JIMS with 10:1 compression, 585G cams, ported heads, RB Racing LSR 2:1 exhaust. I have read about adding the O2 sensors in on the 05 and 06 touring bikes and using a PowerVision but do not know how that would be set up or if really possible.
wowendt is offline
post #2 of 2 (permalink) Old 08-11-2014, 06:38 PM
mitchdm's Avatar
I used a PCV with Autotune on an 06, worked great for 93k. No reason why you can't use a power vision and the autotune. I would probably goto S&S for a Base map on one of their 117's or if you buy the PV etc from Fuel Moto, I'm sure Jamie has a map that will be close from a 117.
mitchdm is offline
SE tuner and Power Vision tuner question bigshaqa *General Road Glide Discussions/Pictures 8 01-11-2015 09:35 PM
tuner no tuner WTH????? motosig102 Intake and Exhaust 19 06-16-2013 02:36 PM
HD Super Tuner vs HD SE Street Perf Tuner mhud3780 ECM/Fuel Management systems 1 02-18-2013 10:00 AM
