Between shifts....pop - Road Glide Forums
post #1 of 5 (permalink) Old 08-16-2014, 04:37 AM Thread Starter
longrides's Avatar
I've run several sutotunes and still get a little pop between shifting lower gears.... particularly on hard acceleration. What is causing that..... the map or something else?
Currently Bikeless
Shopping for a '15 or '16 found one and it aint HD
2013 FLTRX Black Denim - 4" ceramic Jackpots, Fullsac X pipe header, PV w/FM map - gone but not forgotten
2008 Anniversary Edition,
gone but not forgotten.
longrides is offline
post #2 of 5 (permalink) Old 08-16-2014, 05:03 AM
The map may have it to lean.
post #3 of 5 (permalink) Old 08-16-2014, 06:44 AM
09Sharknose's Avatar
Sounds like decel pop. Usually caused by one of two culprits: 1) map too lean or 2) exhaust leak
09Sharknose is offline
post #4 of 5 (permalink) Old 08-16-2014, 07:56 AM
RoadGlideGary's Avatar
^+++ what 09Sharknose says.
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #5 of 5 (permalink) Old 08-16-2014, 10:53 PM
Banned
Typically your symptom is caused by a lean condition remedied by adding fuel to the decel enleanment table, however, sometimes it can happen from being too rich on the same table. I'd start by adding fuel in the decel enleanment table by adding maybe 10-15% more fuel there and try it. If that doesn't work, try adding more fuel. If that doesn't cure it, go the other direction and pull fuel out in the same table. Try this AFTER you've made sure that you don't have a simple exhaust leak that is sucking ambient air into the exhaust system. That can also cause the problem you're describing.
INDY #1 is offline
D&D Gatcat exhaust installed, gurgling-pop on shifts georgec Troubleshooting for Road Glides 0 09-18-2017 08:09 PM
pop on decel w/sampsons deano1svs Intake and Exhaust 11 06-29-2013 10:55 AM
FBI Low Profile Dash & Pop Up Gas Cap Swagzilla Paint & Bodywork Section 12 07-19-2012 12:00 PM
Front brakes pop. Radioactive Troubleshooting for Road Glides 5 08-31-2011 11:35 AM
