T max tuner questions. Dyno results - Road Glide Forums
post #1 of 2 (permalink) Old 09-11-2014, 07:57 PM Thread Starter
I was thinking today. If you had a base map loaded and ran auto tune a few times. Then hit the dyno for a tune. Will the numbers close before and after. Anyone did this?
milkman48 is offline
post #2 of 2 (permalink) Old 09-12-2014, 10:31 AM
The reason I got the T-max was so I didn't have to spend money on dyno tunes. If you know how to make timing changes and AFR changes and the bike is running good I would bet that there wouldn't be much difference.
Thunder Max Auto Tuner Flanz ECM/Fuel Management systems 68 05-29-2015 09:11 PM
T-Max vs Every Other Tuner!! Q-Hog Equipment-RG 3 12-17-2012 09:30 PM
What questions to ask of a Dyno Tuner? Hullhorr Dyno Results 3 12-13-2012 02:02 PM
