Tune help- TTS,13 FLTRU w naked intake - Road Glide Forums
post #1 of 1 (permalink) Old 09-11-2014, 09:26 PM Thread Starter
adown's Avatar
Hi all. I'm getting pinging at steady cruise anywhere from 55mph to 80mph with the slightest uphill or head wind. I pulled a flight recording, and the front cyl pulls about 1.5* when MAP starts climbing above 55kph. The rear cyl pulls up to 10* (average 4.5*) when the MAP gets up to 65-70kph at 3000rpm. I was just going to pull a couple degrees starting at 2500rpm above 55kph, but I'm nervous about doing it without checking first.
PS: IT DID THIS RIGHT FROM THE FACTORY, IT IS NOT THE TUNER.
Doc is always willing to help, but I feel bad asking. Even though I've purchased two tuners from him; he makes a living tuning bikes in his shop, not over the phone.
Does anyone have a map for a stock 13 FLTRU with a V&H naked intake that doesn't ping.
Thanks, adown
adown is online now
'18 114-in Stage=4 with TTS cams and TTS tuner Sharkbreath Dyno Results 12 12-16-2017 10:02 AM
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
Needing help with TTS V-Tune LMS ECM/Fuel Management systems 20 05-04-2011 04:38 PM
V&H Vo2 Naked Intake, any good? Seven3smoke Intake and Exhaust 5 12-28-2010 02:00 PM
