PCV with autotune - Road Glide Forums
post #1 of 3 (permalink) Old 09-16-2014, 08:15 PM Thread Starter
dwighop's Avatar
PCV with autotune
So I got back from a nice trip in the mountains and the bike is running pretty bad in rpms up to 2500 in every gear. Check the autotune map and -20s all around that rpm on both cylinders. Check my ECM codes and all sorts of ECM codes (p0134, p0154, u1301, u1064, p1003, u1097, p0031). What has gone wrong? Sensors fouled? Autotune shot? ECM?
Edited for 0134 not 0135
dwighop is offline
post #2 of 3 (permalink) Old 09-17-2014, 06:00 AM
hometoast's Avatar
P0154 Rear Oxygen Sensor Inactive
P0135 bad sensor
U1301 ECM Serial Data High
U1064 Loss of TSM/FSFM Serial Data to ECM
P1003 System relay contacts open
U1097 Loss of Speedometer Serial Data to ECM
P0031 bad sensor
First thing I'd do is double check your connections to/from the ECM. Loose plug? The U1097,U1064 codes makes me think it's more a ECM connection than an o2 sensor connection.
PM me if you could use a Electrical Diagnosis manual.
2013 Candy Orange FLTRX
hometoast is offline
post #3 of 3 (permalink) Old 09-17-2014, 06:22 AM Thread Starter
dwighop's Avatar
PCV with autotune
I will recheck connections. Maybe with seat coming off a few times they got tweaked. But why would the values from autotune be so far off the chart? I've had it on the bike over a year and accepted several tables.
dwighop is offline
PCV autotune dwighop ECM/Fuel Management systems 11 01-19-2013 08:43 PM
PCV and Autotune Module F/S x52gnr Classifieds Archive (3 months old+) 6 04-23-2012 06:03 PM
PCV Autotune timing 615McCord ECM/Fuel Management systems 2 02-14-2012 09:06 AM
PCV Autotune 615McCord ECM/Fuel Management systems 3 11-26-2011 08:42 PM
PCV AutoTune full exhaust and stage 1 filter 615McCord Road Glide Specific Discussions 1 11-13-2011 07:20 PM
