Power Vision pc users......will it work with Windows 8.1 - Road Glide Forums
post #1 of 17 (permalink) Old 09-20-2014, 10:11 PM Thread Starter
Easyryder01's Avatar
I bought a Microsoft Surface Pro tablet to use in my garage and traveling. It uses Windows 8.1 and I think I was told the power vision does not operate with that os. For you guys that play with the power vision tables/cells shoot me some info if ya can.
2017 RGS Velocity Red
Easyryder01 is offline
post #2 of 17 (permalink) Old 09-21-2014, 01:01 PM
AtomiCapricorn's Avatar
The Dynojet website says that WinPV is compatible with XP, Vista, and 7.
'13 FLTRX, BBP, Vivid Black painted inner fairing, 9" Windsplitter, 14" W1 Chubbys, Get-A-Grips, Daymakers, ABS, Cruise, Security, 4 Speaker HW/Jensen HD1BT System, Fuel Moto Jackpot Header/Nightstick Exhaust, Powervision, Fueling 543 cams (95HP/104TQ). Yay, me!!
AtomiCapricorn is offline
post #3 of 17 (permalink) Old 09-21-2014, 01:03 PM Thread Starter
It says 8 as well but I don't know if it is the same as 8.1. Never thought about the os until I started to use the pv-1
post #4 of 17 (permalink) Old 09-21-2014, 01:13 PM
You are absolutely correct. I missed that part when I looked it up. No idea about 8.1.
post #5 of 17 (permalink) Old 09-21-2014, 01:18 PM Thread Starter
Have you permanently mounted your pv-1 and just use a laptop on the bike ? What os are you using ?
post #6 of 17 (permalink) Old 09-21-2014, 02:25 PM
It's semi-permanently mounted with an Iron Aces Speed Shop Road Glide Mount. I've only hooked my PV up to my computer twice: once was right after I bought it and flashed my ECM the first time, and the second was after I ordered my Jackpot header and FM intake, so I could load the map that Jamie sent me. Both times it was connected to my PC when it was off my bike. I'm running Windows 7 on a four year old PC.
post #7 of 17 (permalink) Old 09-27-2014, 12:20 PM
Boogitybob's Avatar
I cannot get it to work with my 8.1 on my laptop Any help will be appreciated
BoogityBob
2013 FLTRU Vance and Hines Dresser duals,Monster ovals, VO2 naked intake, and Power Vision
Boogitybob is offline
post #8 of 17 (permalink) Old 09-27-2014, 12:31 PM
skratch's Avatar
i have 8.1 on my desktop. i have not had any problems running it.
skratch is offline
post #9 of 17 (permalink) Old 09-27-2014, 01:00 PM
Boogitybob's Avatar
when I try and open a downloaded tune a message comes up and says this ap can't run on this pc Check with software publisher. HELP
BoogityBob
post #10 of 17 (permalink) Old 09-27-2014, 06:53 PM
skratch's Avatar
download the tune to your desktop (it is a pvt tune correct?). open winpv, then open the tune through the program.
it sounds like the file extension is not set to winpv as the default.
skratch is offline
PC V or Power Vision hdclassicman ECM/Fuel Management systems 14 08-22-2014 08:22 AM
windows 8 and power vision Boogitybob ECM/Fuel Management systems 9 03-06-2014 05:49 AM
Power Vision and PC IV Deadstroke ECM/Fuel Management systems 9 01-29-2014 01:40 PM
Windows 8 h-donut General Off-Topic Discussions 18 01-27-2013 03:05 PM
Power Command Power Vision problem help! BigDave55 ECM/Fuel Management systems 11 08-06-2011 07:21 AM
