Looking for a map - Road Glide Forums
post #1 of 5 (permalink) Old 09-23-2014, 11:57 PM Thread Starter
goose2's Avatar
Looking for a map
I am looking for a map for a power vision. My ride is 2012 glide with a stock 103, screamin eagle heavy breather and vance and hines pro pipe 2 into 1 exhaust.
With the map fuel moto sent me the bike runs great but it pings like a bitch between 2-3000 rpm range. I have tried the auto tune three different times with the same outcome. Ping, ping, ping. Hoping someone mite have a fix for me.
Thanks in advance.
goose2 is offline
post #2 of 5 (permalink) Old 09-24-2014, 01:33 AM
Punishher7's Avatar
Email fuel moto. If you bought from them they will send you maps for free.
2013 RGC
Punishher7 is online now
post #3 of 5 (permalink) Old 09-24-2014, 01:21 PM
rageglide's Avatar
Not to mention, I'm sure Jamie will help to resolve the problem.
It's odd tho, I've never once had pinging issues with my set up. Even when hotter than hades. Maybe you're in too tall a gear for the load? I rarely shift before 3k and when I'm in 6th RPM is almost always above 3k...
You might consider "Load copy current tune" (wording is weird, but it downloads a copy of what's in the ECM) to the Power Vision unit, then take the PV unit to your computer where WinPV is installed, hook it up and download the "Copy of current tune" and the tune you got from Fuel Moto. Open one tune, then load compare. If you don't see very obvious differences in the before auto tune map and your ECMs current map, then you may not be doing Autotune correctly. It's easy to make a mistake in the process.
2012 fltrx
rageglide is offline
post #4 of 5 (permalink) Old 09-24-2014, 04:17 PM
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Thanks in advance.
We can very easily revise your map for you. To request tuning assistance you can use the map request form http://www.fuelmotousa.com/fuel-maps.html you will include your bike info, attach your current map, and let us know any specific issues you are encountering. If you need additional assistance you are also welcome to contact our technical dept at 920-423-3309
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #5 of 5 (permalink) Old 09-24-2014, 04:37 PM Thread Starter
goose2's Avatar
Thanks for the help guys.
goose2 is offline
Need map and have map to share Hack73 Map Section 0 10-03-2016 04:42 AM
Looking for a Map Wmoor004 Map Section 0 06-07-2014 02:26 PM
Looking for Map Brianu1 Map Section 0 06-01-2014 09:21 AM
: Looking for a map for my Power vision SE/Air Cleaner SuperTrapp 2:1 SuperMeg Scotd Map Section 3 08-28-2013 03:58 PM
Looking for PC V map sftosendai Road Glide Specific Discussions 0 06-14-2011 11:23 PM
