Thundermax without Autotune? - Road Glide Forums
post #1 of 4 (permalink) Old 10-01-2014, 01:36 PM Thread Starter
I have been looking around trying to find some answers on this so hopefully someone here can shed some light for me. The 2006 RG I just got has a Thundermax tuner on it but it does not have Autotune. The bike has an intake and exhaust (not sure what brands) and all the work was done prior to me buying it. Is the Thundermax without an autotune on this bike an issue or does it just limit the flexability of tuning? The bike runs great but I am just thinking for down the road if I change anything how I would change the tune. Thanks for any help.
JStegs63 is offline
post #2 of 4 (permalink) Old 10-01-2014, 03:02 PM
McLuvin's Avatar
There are some Thundermax geniuses on here but, I believe if you made changes like big bore, cams or heads you could take it to a tuner that would dyno it and make a custom map for you. The one in it now is probably a canned map. If i'm wrong someone else correct me. Welcome to the forum.
McLuvin
excuse me while I whip this out...
McLuvin is offline
post #3 of 4 (permalink) Old 10-01-2014, 09:25 PM
Hullhorr's Avatar
I thought all of the Thundermax tuners were auto tune. Perhaps the earlier models were not. If that is the case then what McLuvin would be correct.
2009 FLTR MOP
Hullhorr is offline
post #4 of 4 (permalink) Old 10-02-2014, 07:00 AM
mocotom's Avatar
The first Thundermax versions were not auto tune, however when they came out with the A/T module you could purchase it seperately. I would call Zipper's and see if they can be of any help. The T-Max basic can be dyno tuned just like any other system but finding a shop that works with them will be your challenge. The bright side is Zipper's location is not that far from you, just south of Baltimore, Md on route 100.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
Thundermax autotune, Jensen HD1BT Sirius XM tuner, Edge Cut latches, docking station daryl_db Parts for Sale 6 03-18-2015 08:56 AM
Thundermax autotune ecm part # 309-362 for 08-13 touring RIDERED67 Sold 3 09-09-2013 08:36 AM
Stock ECU & VH Fuelpak vs T-Max Autotune DAK47 ECM/Fuel Management systems 3 12-03-2010 09:48 PM
