what would you do?? - Road Glide Forums
post #1 of 12 (permalink) Old 10-06-2014, 02:48 PM Thread Starter
what would you do??
I have a 2009 Ultra with 12,800 miles on her. Last weekend I went to myrtle beach and the bike died. It has a PC5 on it that i installed from fuel moto,(Jamie) a couple of years ago. I had it tuned and dynoed from a PC dealer at beach about same time. Anyways, bike dies so I checked a few things and finally unplugged pc5 and bike started. did this a few times so left it off and bike ran fine. Question is what should I do, try another pc5 or go to HD and try their race tuner or what works that will last? Bike is stock except a/c and exhaust slipons, and $$$ is tight. what is best route for me to go?
forace2009 is offline
post #2 of 12 (permalink) Old 10-06-2014, 02:54 PM
sfcusaret2004's Avatar
Contact Fuel Moto. I hear they have great customer service. Tell them what happened and see where it leads. If it runs without the PC5 then what have you lost?
sfcusaret2004 is offline
post #3 of 12 (permalink) Old 10-06-2014, 02:56 PM Thread Starter
I have done so and am waiting to hear from them just in case. Thanks
post #4 of 12 (permalink) Old 10-06-2014, 03:14 PM
See what FuelMoto will do to get you into a PowerVision?
HeatWave is offline
post #5 of 12 (permalink) Old 10-06-2014, 04:53 PM
NightRider VIED for around a buck. If all your running is air cleaner and pipes it will be fine.
post #6 of 12 (permalink) Old 10-06-2014, 07:34 PM
If that's all you've done to it! Leave it off, likely wasn't doing right in the first place for just [freeing] opening breathing&exhaust which is the standard to do anyways
reds4 is offline
post #7 of 12 (permalink) Old 10-08-2014, 11:08 AM Thread Starter
thanks, but hopeing for more info!
Ok you are right about all I have done, but a friend has a 2009 street glide with same mods, had a HD race tune downloaded and tuned and unless you have a built bike he cannot be beaten, thats how much difference there is in our 2 bikes. My question is ??? does a PC5 being tuned and dynoed and tuned, not do very much for you? Does a race tune from HD make that much difference? We bought bikes from same dealer almost same time and I know he has not been into the engine, but nobody around here can touch him unless they are really built. I am looking for info.
Thanks
post #8 of 12 (permalink) Old 10-08-2014, 11:16 AM
wjco9's Avatar
I used the HD SEPST tuner and had local HD shop dyno it she runs better than anyone else's I ride with and doesn't void the warranty
Live to Ride
Ride to Eat
wjco9 is offline
post #9 of 12 (permalink) Old 10-08-2014, 12:50 PM
Seems with FI and all the plug&plays there're it's a matter of adjusting to your style and how hard you want to transfer pwr & economy. Had our '03 95" hookers and highflow (PCIII) dynoed tuned once in '05 and it ran like shit in the mountains, ting on pulls, 2up fullyllaoded or not. Upgraded the injectors and laptop loaded and manually adj the PC for my style. Looking back or just the 200mi up 101N last wknd there is only so much range in FI without engine work.
reds4 is offline
post #10 of 12 (permalink) Old 10-08-2014, 04:35 PM
charlieb's Avatar
if you have not solved your problem yet, it is easy for you to hook the pc5 up to your computer and throw a canned tune on it and try it again on your bike to see if thats the problem files can become corrupt and not work or the commander could be pouched i did my own last year i believe you can store the dynoed file while adding the canned and switch from 1 to the other
charlieb is offline
What would you do if you had $300 RDCantu *General Road Glide Discussions/Pictures 40 04-22-2012 09:38 AM
Windvest cracked, What would you do? racerdave Windshields 14 03-18-2012 05:12 PM
What would you do? flhr95 Paint & Bodywork Section 3 02-18-2012 06:14 PM
What do you think would be a Good Deal? Ofthirty3 Road Glide Specific Discussions 15 03-17-2011 08:17 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
