Engine started surging - Road Glide Forums
post #1 of 13 (permalink) Old 10-15-2014, 01:37 PM Thread Starter
A quick run down. I have a 2012 RG that has a Power Vision and 2 into 1 and have been running this set up with no changes or problems in the last 2 years.
So what is happening in lower gears at about 1500 - 2300 rpms the motor will surge but only under really light throttle, if it is at idle or under harder throttle it runs fine. This started a couple days after a fairly warm ride in town with stop and go traffic, the motor never really got hot so it may be a coincidence.
I have listened to the tank and there appears to be no fuel line leak issues. also i disconnected the power for a few minutes to see if that might be related for some reason.
This is frustrating due to i found no ecm codes and it runs fine other than light throttle.
Any ideas?
Retired U.S.A.F.
T-N-T is offline
post #2 of 13 (permalink) Old 10-15-2014, 02:43 PM
Gray Beard
lundboy1's Avatar
Wonder if your TBW is going out
" wishin' my knees were in the breeze!!!"
lundboy1 is offline
post #3 of 13 (permalink) Old 10-15-2014, 03:02 PM
FrankieB's Avatar
Reload you map from the power vision see if it helps.
06 RK
11 RGU
FrankieB is offline
post #4 of 13 (permalink) Old 10-15-2014, 03:27 PM
Oil blow-by -- overfill sump recently?
Air cleaner loose and/or dirty?
Gas station changed over to oxygenated fuel for Winter?
Carbon build-up on valves/heads/plugs?
Most likely: you got a crappy load of fuel.
August is offline
post #5 of 13 (permalink) Old 10-15-2014, 10:16 PM
How many miles on the bike? Check your spark plugs and and wires, you may want to change your fuel filter too. Plugs are cheap enough and it wouldn't hurt to change them out.
post #6 of 13 (permalink) Old 10-16-2014, 11:56 AM
It doesn't hurt to do a basic tune up plugs and a fuel filter would be the best thing to do no matter what. You can check the plug wires with a multimeter if the plug wires are good you should have 5.3 to 5.8 ohms of resistance.
You may have a small vacum leak, there is a rubber plug on the top of the throttle body that may be cracking or the rubber throttle body gaskets may be cracking.
post #7 of 13 (permalink) Old 10-16-2014, 09:54 PM Thread Starter
Ok, I checked some things today. Filter, plugs, wires, and such. It just got a tune up at Harley 1800 miles ago. I have a prepaid MX plan that they gave me when I bought it and it is almost time again so I may just let them look at it.
One thing I found is that the rear spark plug was fairly loose. I took it out for a ride today and it did fine up until about 15 minutes of riding. It is not so much a surge as stated before but a quick loss of power, this is only occuring under extremely light throttle.
Thank you to all that gave some tips to look at.
Retired U.S.A.F.
T-N-T is offline
post #8 of 13 (permalink) Old 10-17-2014, 01:31 PM
rageglide's Avatar
You can try reloading your tune. Or just accept it as normal for a really lean light load mixture.
Mine does this too. I attribute it mostly to tune drift because if I reload it will go away for a few days, then return. Typically only does it for me when I'm on a downhill grade and throttle is barely open. It's most noticeable when the bike is cold. Like when I get on to go home from work.
It's not likely hurting anything, but I know how you feel, it's a weird feeling. IMO, as long as it's not present under load I would not worry about it.
2012 fltrx
rageglide is offline
post #9 of 13 (permalink) Old 10-18-2014, 12:19 PM Thread Starter
Thanks RoadRage. I will find my tuner box, i just moved so i do not know where it is. I do not feel it is bad, just friggin annoying.
Retired U.S.A.F.
T-N-T is offline
post #10 of 13 (permalink) Old 10-30-2014, 07:55 PM Thread Starter
Thought I would post up again. Found it to be the plug wires, Harley uses those zip ties that secure the wires up to the frame away from the motor, must have been to tight and the heat melted the wire around the zip tie. New wires and she runs like a champ again.
Thanks for all the help.
Retired U.S.A.F.
T-N-T is offline
Engine Surging at idle Gixxere Engine Related 11 02-25-2015 03:21 PM
surging crustye Troubleshooting for Road Glides 3 02-15-2013 10:56 AM
Engine surging LittleMoe Troubleshooting for Road Glides 13 08-28-2012 07:46 PM
The outing thread: I started my glorious career with ... LouRider General Off-Topic Discussions 6 04-19-2010 07:43 PM
Started to black out the Road Glide Sonar_Chris *General Road Glide Discussions/Pictures 18 01-10-2010 12:42 AM
