New TTS Mastertune owner - Road Glide Forums
post #1 of 10 (permalink) Old 10-17-2014, 07:46 PM Thread Starter
dnschmpn's Avatar
I just purchased a TTS Mastertune and I cannot get the program to recognize my bike. I get the green light with connectivity, it says it finds the J1850 ECM but when I go to get the ECM info it tells me the VIN not found, ECM not found, etc. I have updated the software and the USB drivers and still no luck. I noticed in my ECM plug there are only 3 male ends. DO I have the right connector? I am using the only plug under the fuse panel on the left side.
After an hour and the instruction manual I figured it out
You tube left out a key component of the instructions.
Enjoy the Ride!
2013 RGU in Big Blue Pearl
dnschmpn is offline
post #2 of 10 (permalink) Old 10-17-2014, 10:29 PM
hd4cruzin's Avatar
What was the fix?
2012 FLTRX BBP
hd4cruzin is offline
post #3 of 10 (permalink) Old 10-18-2014, 09:34 PM Thread Starter
dnschmpn's Avatar
Not only do you turn on the power from the ignition switch but you have to flip the handlebar switch into the run position. Then it worked like a charm.
Enjoy the Ride!
dnschmpn is offline
post #4 of 10 (permalink) Old 10-18-2014, 09:44 PM
idahointrudr's Avatar
On my list along with cams for my 13 BBP!
2013 BBP TTS Tuner, Andrews 222 cams. Black Heritage bars, Dragos H Pipe, Madstad shield, Sanchos Wings
idahointrudr is offline
post #5 of 10 (permalink) Old 10-19-2014, 09:05 PM Thread Starter
dnschmpn's Avatar
I'm very happy with the purchase. It will do more than I will ever try to figure out but I do like the fact that it has a "flight recorder" mode where you can ride with a laptop and it will suggest changes.
Good luck wit the cams.
Enjoy the Ride!
dnschmpn is offline
post #6 of 10 (permalink) Old 10-20-2014, 06:42 AM
Flight recorder will allow you to setup so you can just ride with the dongle attached without any need for a laptop. You can use data master to actively use a laptop but no need to ride with one in your saddlebag anymore. This is assuming you have the blue TTS dongle. Vtune is an excellent product and with some patience and understanding works very well. Enjoy
2011 Road Glide Custom
2006 Street Glide 124 - SOLD
1999 Road Glide
Njbagger is offline
post #7 of 10 (permalink) Old 10-20-2014, 11:23 AM
Glidr's Avatar
I've had the TTS for about a year now and after some initial stumbling blocks like what you ran into I really like it. As I understand it, some guys have a great understanding of the Vtune and get great ongoing results using it.
I found it to be a little more confusing than helpful and I'm going to see Doc in November for a dyno session. He was the one who recommended it in the first place and I keep hearing amazing things about how he uses the advanced capabilities of the TTS.
Good luck!
'13 RGC Vivid Black, Windvest, HID upgrades, 14" Buky Assaults with chromed top end, Heavy Breather, Fullsac Sportpipe, Rinehart 4", SE 255, TTS Mastertune, PM Launch 21/17 Xquisite cut, a few other chrome pieces and a list of plans like the rest of us.
Glidr is offline
post #8 of 10 (permalink) Old 10-20-2014, 05:37 PM
124shark's Avatar
Doc will get your bike tuned up. You will be amazed at how well a correctly tuned bike runs.
2012 FLTRX 124 S&S
124shark is offline
post #9 of 10 (permalink) Old 10-20-2014, 07:48 PM Thread Starter
dnschmpn's Avatar
Thank you all for the input. Looking forward to learning about this thing. I do have the blue dongle so it is nice to know I do not need to ride with the laptop connected.
Enjoy the Ride!
dnschmpn is offline
post #10 of 10 (permalink) Old 10-20-2014, 10:13 PM
Glidr's Avatar
I've heard nothing but good things and have had several insightful conversations with Doc leading up to this appointment. I'm looking forward to the tune date and riding it after.
Glidr is offline
TTS MASTERTUNE w/ Software and TTS USB cable. Raiderse Classifieds Archive (3 months old+) 0 05-17-2012 04:08 AM
TTS MasterTune Map to stop Ping and high heat 2011 RGU? Raiderse ECM/Fuel Management systems 15 05-10-2012 01:52 PM
TTS mastertune schuldtp ECM/Fuel Management systems 16 01-17-2012 08:24 PM
TTS Mastertune & a New Header Martin ECM/Fuel Management systems 5 06-25-2011 05:33 PM
Get a great deal on TTS MasterTune BDMastiff Engine Related 35 05-28-2011 07:22 AM
