2015 roadglide gas - Road Glide Forums
post #1 of 11 (permalink) Old 10-23-2014, 11:30 PM Thread Starter
2015 roadglide gas
2015 roadglide with performance machine breather, thunderheader full 2into1 exhaust and SERT. Bike only gets about 160 miles to the tank.
I don't think the SERT tune is right because the deal ship I bought it from doesn't have a dyno.
I wonder if they just did the standard "DownLoad'
platinumnj is offline
post #2 of 11 (permalink) Old 10-24-2014, 04:27 AM
HellInABucket's Avatar
Even if they did, that would not be the cause of your problem.
2020 FLTRK
Roll away the dew...
HellInABucket is offline
post #3 of 11 (permalink) Old 10-24-2014, 06:51 AM
124shark's Avatar
The pro tuner can tune in smart tune mode ( closed loop) on the street and not neede a dyno,.. cruise range = MPG.
However with the pipe you have there is not a great starting map. It would take several changes on a dyno to get it into a some what close ball park. So if a map was just down loaded and a small amount of street riding in smart tune. There is your issue without a doubt. Take the bike to a shop that understands the Harley Super tuner and have them build a custom map for your bike
To get that poor of MPG the tune is in open loop and incorrect or they left it in closed loop but the map is extremely off target. Either way it needs to be corrected.
Down load the soft ware from HD buy the cables read the instructions and go make some smart tune's on your own. You can get it closer in the mean time.
Here is a link you can watch step by step on how the system works.
http://prosupertuner.harley-davidson...ing/index.html
2012 FLTRX 124 S&S
124shark is offline
post #4 of 11 (permalink) Old 10-24-2014, 06:55 AM
93-331-29psi's Avatar
What he said.... you're running way rich to only get 160 a tank
93-331-29psi is offline
post #5 of 11 (permalink) Old 10-24-2014, 07:13 PM
How many gallons is it taking to fill up? you say 160 per tank but your gauge or low fuel light could be off , unless we know how many gallons its taking for that 160 miles its anyone's guess what may or may not be the problem, if its only taking 4 gallons then your getting 40 MPG which is average .
Although you have gotten some good advice I think more info is needed on fill up gallons .
Eagle is offline
post #6 of 11 (permalink) Old 10-24-2014, 07:19 PM
RoadGlideGary's Avatar
Holly crap something is not correct. My two generation old '08 get 44 in town and 50 plus on the highway. Better trade it in and get an older model!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #7 of 11 (permalink) Old 10-26-2014, 10:50 PM
That is ridiculously low. I just had a stage 1 done a few days ago and went out for a 230 mile ride and still have about another 30 to 40 miles left.
Inforit is offline
post #8 of 11 (permalink) Old 10-27-2014, 07:50 AM
perrykw's Avatar
I'm not a tuner expert, but that does seem very low. Mine gets well over 200 on a tank. I'm on a stock tune, but from what I've heard the tune improves the gas mileage, not makes it worse.
perrykw is offline
post #9 of 11 (permalink) Old 11-07-2014, 10:43 PM
JetDe's Avatar
Somthing a miss
Something is not functioning as designed.
I'm running full open loop and getting 240-260 miles a tank depending on how heavy the right wrist is working... and the terrain, etc. of course,
Bottom line: something needs attention to add another 90 miles of distance to your fill-ups.
Good luck.
2013 FLTRU 120ST SEST/PV-TT tuning underway
2010 FLHTCU 107" GMR built; PV tuned by me - gone
2007 FLSTC 117" GMR built; SERT/TTS tuned - gone
JetDe is offline
post #10 of 11 (permalink) Old 11-08-2014, 01:04 PM
Figure out your MPG over 5-6 tanks and different riding conditions. The miles per tank does not really give a good indication...
HeatWave is offline
2015 Roadglide bglet *General Road Glide Discussions/Pictures 39 03-25-2015 08:41 PM
Possibiitys of 2015 Roadglide Fairing Neano62 *General Road Glide Discussions/Pictures 2 08-11-2014 07:12 PM
New Roadglide for 2015 OH_SO_LO *General Road Glide Discussions/Pictures 3 08-03-2014 11:05 AM
Tank gas question, smell gas Dirty Irish *General Road Glide Discussions/Pictures 3 12-22-2011 03:39 AM
