PV Autotune run, is this normal... - Road Glide Forums
post #1 of 7 (permalink) Old 10-29-2014, 10:53 PM Thread Starter
Made my first autotune basic run today on my RGS. Forty five minute ride on a combination of interstate and stop-and-go secondary roads. PV screen showed more then 90 percent of the cells (?) in the "red". Saved and downloaded the AT map.
Tonight when comparing the Fuelmoto MAP that came with the PV to the autotune run MAP on WinPV, there was no difference in the AFR table values between the two. There was a difference in the VE table values for both cylinders between the two.
Is this normal? Is this where the "fine tuning" of the MAP occurs?
regards,
2015 RGS
2016 R1200RT
Rsmith is offline
post #2 of 7 (permalink) Old 10-30-2014, 05:43 AM
Sounds like you had a good tune to start with. I think the cells turn red when there has been a certain number of samples recorded for that cell and not necessarily significant changes in that cell. Sounds like the VE values are being fine tuned.
Captain13 is offline
post #3 of 7 (permalink) Old 10-30-2014, 07:18 AM
The AFR table doesn't change. The only table you will see changes on is the VE table front and rear. One VE table is lined out you can change AFR table to what you want.
pittz5 is offline
post #4 of 7 (permalink) Old 10-30-2014, 07:37 AM
mocotom's Avatar
The A/F tables are set to what fuel ratio you want the motor to operate. The PV adjusts the VE tables to attain that ratio.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #5 of 7 (permalink) Old 10-30-2014, 08:24 AM
124shark's Avatar
Its nothing more than a marker to show you where you have ridden. AFR will not change VE only. I would suggest that you shorten the trips up to 10-15 min segments. There is only so much data that can be gathered..
2012 FLTRX 124 S&S
124shark is offline
post #6 of 7 (permalink) Old 10-30-2014, 10:42 AM Thread Starter
Thanks to all who have answered. Wasn't sure how the autotune basic feature "tuned".
regards,
2015 RGS
2016 R1200RT
Rsmith is offline
post #7 of 7 (permalink) Old 11-07-2014, 10:36 PM
JetDe's Avatar
LIbrary Here
Originally Posted by Rsmith View Post
Thanks to all who have answered. Wasn't sure how the autotune basic feature "tuned". regads,
Here is the PV 'library' from DJ, make use of this, you can't go wrong:
http://www.dynojet.com/PowerVision/p...Power%20Vision
Lots of good info on making good use of the PV.
Good Luck!
2013 FLTRU 120ST SEST/PV-TT tuning underway
2010 FLHTCU 107" GMR built; PV tuned by me - gone
2007 FLSTC 117" GMR built; SERT/TTS tuned - gone
JetDe is offline
Cannot enable autotune on my PV Beaver ECM/Fuel Management systems 6 04-15-2017 01:14 PM
Auto tune run with PV gja ECM/Fuel Management systems 2 05-29-2014 10:34 PM
Normal or not?? big papa *General Road Glide Discussions/Pictures 4 09-27-2011 10:42 AM
Does this sound normal to you? Dandy1 *General Road Glide Discussions/Pictures 19 03-23-2011 04:06 PM
A good dose of "Normal" Tytanium *General Road Glide Discussions/Pictures 30 03-09-2011 02:51 PM
