Anyone using the V&H FP3 - Road Glide Forums
 3Likes
post #1 of 24 (permalink) Old 11-06-2014, 05:30 AM Thread Starter
garbage cannon's Avatar
Location: On the southern shore of Lake Arthur of Moraine State Park. About 40 miles north of Pittsburgh
Been looking at the fp3 and wanted to know if anyone has installed these.
It's funny how we keep expecting leaders from a system that rewards weasels.
garbage cannon is offline
post #2 of 24 (permalink) Old 11-07-2014, 11:57 AM Thread Starter
Nobody huh. Not even a friend of a friend?
post #3 of 24 (permalink) Old 11-07-2014, 12:03 PM
I have sold a lot but we do not have a 14 or 15 bike here as of yet.
HogPro is offline
post #4 of 24 (permalink) Old 11-24-2014, 02:55 PM
I have it on my 2015 RGS.
Inforit is offline
post #5 of 24 (permalink) Old 11-24-2014, 03:11 PM
How do you like it Inforit?
Drew
HogPro is offline
post #6 of 24 (permalink) Old 11-24-2014, 03:17 PM
Runs great for me. Besides the slight decel pops that I got with a canned map from Vance and Hines with my MGS true dual setup. I auto tuned it, and after that the the decel pop went away.
Inforit is offline
post #7 of 24 (permalink) Old 11-24-2014, 03:50 PM
Good to get first hand experience. Thanks for the info. Enjoy.
Drew
HogPro is offline
post #8 of 24 (permalink) Old 11-27-2014, 01:07 AM
Inforit I have the same setup with mgs true duals and VH FP3. which canned map are you using? vance/hines dresser duals with high flow air intake?
I experience the light decal pop but have not done autotune yet. How long did you autotune? a full tank? a specific amount of time?
Thanks for any info!
whiskeyMO is offline
post #9 of 24 (permalink) Old 12-08-2014, 01:00 AM
Yes, and I also tried the one with Q insert, I think its called, and made the decel pop less. I tuned the bike for about 2 tanks of gas. Constantly updating it. The first update was around 50 miles and the decel went away completely for me. I think I should of stopped then. Because after doing about 5 updates to the auto tune in those 2 tank fill ups made the torque less aggressive in first 3 gears. I am going to reset the map and start fresh and make a quick ride about 50 miles or so to just get ride of the decel popping and be done with it. Because that map otherwise works very well for my setup. Let me know what your results are and what you did.
Inforit is offline
post #10 of 24 (permalink) Old 12-08-2014, 06:37 AM
HenryG's Avatar
Installed the FP3 on my 2015 RGS last week. Got snow the next day so can't give you any ride feed back yet. Install was flawless and the tune ability appears to be endless with access to VE tables, timing, idle, throttle progressivity, spark advance, etc. I have used PCV & SERT in the past. I will be comparing input tables with my SERT to the FP3 and experimenting with those maps for the 2015s just for shits & giggles. From what I've been reading....the base FP3 maps w/ auto tune work great.
Best of luck.
H
To ride and to discover, is to be!
HenryG is offline
Anyone using the RF PBR300.4 &....... maddmoe Audio 1 08-01-2016 09:47 AM
V&H FP3 Value Bundle & Fuel Moto package deals fuelmoto Fuel Moto 0 04-10-2015 11:50 AM
Anyone using "Focal" component set up with Rockford Fosgate 300 amp? Valduzy Audio 2 04-04-2014 01:13 AM
Anyone using the S&S 510c cam in your bike? yzernie Engine Related 13 05-22-2013 06:42 AM
Anyone using a S&S high flow air cleaner Hawkeyestoob Road Glide Specific Discussions 9 08-13-2011 09:07 AM
